Old 05-28-2014, 05:34 PM   #1
fresh water drain
The fresh water drain on my unit (2502S) is the same as the low point drains. There is a black cap to unscrew to drain it. It is located on the middle of the tank between the axles. It is a pain to crawl under there and remove the cap. Has anybody done a mod on this? Any idea's? Looking to install some kind of valve on this too.
gserve is offline   Reply With Quote
Old 05-28-2014, 05:36 PM   #2
TURBS's Avatar
I'm not doubting you but are you sure there the same?
TURBS
"Sabre owners united"
Old 05-28-2014, 05:40 PM   #3
Yes, The only differance is this fitting is screwed into the tank and has the same male threads and cap as the low point drains. Low point drain fittings are crimmped to pex pipes.
Old 05-29-2014, 12:04 PM   #4
Post
My Fresh Water Drain has a valve on it. My Low point drains were capped until I added the mod to attach valves last night.
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 05-29-2014, 04:24 PM   #5
Who Dares, Wins
doc73's Avatar
Mine was capped just like the low point drains. Put a hose bib on it. Makes draining quicker and allows me to direct the draining water away from my parking space next to the house.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
drain, fresh water, water
