Old 03-18-2014, 04:43 PM   #1
Davison206's Avatar
Fresh water tank Windjammer 3008
The fresh water tank on my Windjammer 3008 filled with water while city water was connected. Any advice as to why would be appreciated. Thank you.
Sent from my GT-P3113 using Forest River Forums mobile app
Ed and Joyce and Luci Lou
2017 Coachmen Leprechaun 260ds
2017 Ford Escape
Master Tow Dolly
Davison206 is offline   Reply With Quote
Old 03-18-2014, 04:52 PM   #2
Bad water pump check valves. Youroo!!
Old 03-18-2014, 04:53 PM   #3
fonzie's Avatar
The check valve is leaking in your water pump. Might have debris in it. Start water pump for a few minutes and flush. Then try again and see if it fixed it. If not, you will have to take apart.
Fonzie
fresh water, tank, water, water tank, windjammer
