Old 05-28-2014, 08:03 AM   #1
2014 Rockwood 8289WS
Fridge Fan in 2014 Rockwood
So, anyone else out there having issues with their fridge fan (at least we think it is the fan) making a loud humming noise. Seems the hotter it gets outside the more noise it makes. In the evening when things cool down the noise goes away. Similarly on cool days the fridge makes no noise.
Hanksters is offline   Reply With Quote
Old 05-28-2014, 08:07 AM   #2
Your fridge fan is trying to circulate air behind the fridge unit. So naturally it's going to work more on hotter days than evenings/cooler days. Do a search, lots of great info on installing a better/quieter fan.
Old 05-28-2014, 08:14 AM   #3
Witch Doctor's Avatar
x's 2 I had the same problem. Bearings going bad. I bought 2 12 volt fans on ebay then epoxied them together. No problem cooling now and no noise and moves twice the amount of heat and not always on anymore. then you can just use the same mounting. just splice the 4 wires to the existing. I epoxied them side to side.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-28-2014, 08:24 AM   #4
Thanks. I take it this is usual for RV's and not an issue specific to our make, model & year?
Old 05-28-2014, 08:29 AM   #5
You are correct, but some fans are better built and cost more. Which do you think FR put in?
Old 05-28-2014, 08:32 AM   #6
I think I found out this past weekend!
Old 05-28-2014, 04:43 PM   #7
PhoneDude 8289's Avatar
I think the fridg to include the noisy fan are supplied by Dometic. FR just installs them in the RV's.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 05-28-2014, 05:30 PM   #8
You are correct, but FR could spec. a different fan, but that would cost them more by 5.00 bucks or so.
Old 05-28-2014, 05:54 PM   #9
Try standing the fan off the mounting with some rubber, it will help with the vibration. I replaced my fan and it was still noisy so I put some rubber between and much better.
kdcamper 2011chev 3500 slt cc 2013 8329ss dp husky centreline air safe hitch
kdcamper is offline   Reply With Quote
Old 05-29-2014, 01:12 PM   #10
Remove the fan and hook it up to a 12v battery, I used a small battery charger. Run the fan a few minutes. Doing this I still couldn't stand the noise. I changed to two lower RPM fans, together they put out 10CFM more than the single noisy fan. Also built a shroud for the top vent for a smooth exit for the discharge air.
Joe & Beverly
2014 8289WS lifted
2014, fan, fridge, rockwood
