Old 04-01-2016, 07:38 PM   #1
KnP
Furion Rear View Camera (No Power)
My camper came equipped with the rear view camera bracket and power cable. The camera works just fine when I use the power cord for the monitor, so that tells me that is properly paired and does works. Once is plugged on the camper base cable, it seems like it does not get any power.
The camper literature has nothing on the matter. There is a hidden switch that I am not aware of?
2016 Rockwood 2306
2016 Chevy Colorado Z82 / 2009 Pontiac G8 GT
KnP is offline   Reply With Quote
Old 04-01-2016, 07:51 PM   #2
Power to the Rear Camera is supplied when the TT running lights are turned on. I am considering a separate on/off manual switch, but may prefer to just have TT running light son 24/7 when moving - Like on a motorcycle.
The Green wire in the 7Pin supplies the power. See Image
Name:	Hitch Wiring.jpg
270S is offline   Reply With Quote
Old 04-01-2016, 08:41 PM   #3
KnP
Thanks will try in a few mins and will report back...
2016 Rockwood 2306
Old 04-01-2016, 08:53 PM   #4
Dr-G's Avatar
I picked up my first TT a few weeks ago and had a similar issue. Partway home I realized the "Auto" setting on the lights in the TV had to be actually turned to "On" for the camera to work.
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Days Camped '16 - 12
Days Camped '17 - 0
Dr-G is offline   Reply With Quote
Old 04-01-2016, 09:00 PM   #5
KnP
Well, well, well... just walked outside and turned the lights on; sure it worked !!! Dang... ! Who would guessed that one !
Thanks.
2016 Rockwood 2306
Old 04-02-2016, 07:05 AM   #6
Hard to disagree with science. That is why I always have verifiable documentation vs opinion. Hence the image I provided - not just an opinion.
I haven't checked (do not have TT yet) regarding the auto position of the light switch. One probably has to move the light switch to parking lights on or all lights on position in daytime operations to get the green wire in the 7pin plug energized. You could also put a rag over the light sensor on the dash to activate the lights if the switch is in the auto position - lol.
Old 04-02-2016, 02:47 PM   #7
KnP
I can see why is done on that way. If is connected to the Hot Wire it will be on all the time and will drain the battery. So a switch at the base might be a better choice might be a switch at the base; some that you can turn on/off as need it. As using the markers as power source, you can use the Tow Vehicle light switch as the on/off switch. My vehicle has daylight running lights, so is not a big deal to turn the markers on. The rag on the sensor is a great idea, the lights will shut off when the engine turned off.
2016 Rockwood 2306
Old 04-02-2016, 03:07 PM   #8
Back Camera
Just FYI,
If you wan this to be a Observation ( on while Driving Camera) You should be sure to order a Observation system from Furrion, no a Buck Camera system.
The Observation system comes with external Antenna of the receiver unit to provide better reception from the camera. It works great. If you get the Back-up camera system it while break up and lose reception while driving down the road. My trailer is 31'so I could not even get reception while driving. Parking works fine with the Back-up unit but not while driving.
Hope that helps you
speedozeke is offline   Reply With Quote
Old 04-03-2016, 09:08 AM   #9
KnP
I believe I did; stays on all the time (as long the parking lights are on). Just tried and works really neat. One of the things that like is the "night vision'. Not the best, seen better, but is way better than not having it at all.
2016 Rockwood 2306
Old 02-11-2017, 08:35 PM   #10
Turning the lights on was the magic trick. Thanks for sharing the info!
dr. troy is offline   Reply With Quote
power
