Old 11-29-2013, 10:20 AM   #1
Furnace fan
Furnace fan doesn't come on. Checked breakers & fuses by three different people. All other DC appliances work fine. Fan will not come on. Suggestions?
B johnson is offline   Reply With Quote
Old 11-29-2013, 01:36 PM   #2
Owner/Operator
RodeoGeorge's Avatar
Quick way to eliminate the thermostat is to remove it from the wall and tie the two wires from the furnace together. These are normally the white and black wire.
If the furnace begins to operate (fan runs) then the thermostat is defective.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 12-01-2013, 06:02 PM   #3
If I jump the board the fan runs so I thank it's the board . Heater broke in Forest River that's only year and half old used 3 camping trips .
Old 12-01-2013, 06:55 PM   #4
Owner/Operator
You need to clarify the "jump the board" statement.
Are you referring to jumpering the thermostat, or jumpering something on the furnace circuit board?
RodeoGeorge
Old 12-01-2013, 08:00 PM   #5
Power for the Fan goes through the board . Put a hot wire to fan it runs .
The thermostat is ok . I thank I need Dinosaur Electronics FAN 50 PLUS PINS Fan Control Board
Old 12-01-2013, 08:10 PM   #6
Witch Doctor's Avatar
That doesn't mean the stat is good only the fan. You need to jumper it at the stat first. As george said. Your stat contacts could be bad, all you know is the fan works.
Coachmen M/H
Concord
2018 / 300 DSC
