Old 04-17-2011, 08:27 PM   #1
Unhappy Furnace Power
We have a Rockwood (2011 Windjammer 3002W). We noticed the other night (when the furnace was on) that the camper was warm in the living room/kitchen (furnace nearby) but colder in the front of the camper (bedroom). We turned on the furnace and noticed very little air blowing in the bedroom furthest from the furnace. Is this normal? Any help?
Dave & Sheri Herold
dsherold is offline   Reply With Quote
Old 04-18-2011, 03:01 AM   #2
EastlakeRoo's Avatar
Dave & Sheri Herold
I remember the heating/cooling hose not being connected properly in one of our previous trailers. I was able to detatch the vent and connect the hose properly that solved our issue. Just a thought.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 07-07-2011, 11:14 PM   #3
We just purchased the same trailer and find that we have the same problem. I have not looked into it at all. I do know that when the furnace is running, each vent has less and less as you go further from the furnace. I may change the vents to ones that actually can close and close off the first couple to get the air moving to the bedroom at the front
Richard T is offline   Reply With Quote
Old 07-08-2011, 10:34 PM   #4
FarmerMT's Avatar
We have the same issue in our 8312ss. The back bunk house gets very little heat. We are also thinking about putting a vent that closes to force more air to the rear of the trailer.
Phil, Michelle, Logan and Wyatt
2006 Dodge 2500 Heavy Duty 5.7 Hemi
2012 Rockwood 8312ss
FarmerMT is offline   Reply With Quote
Old 07-08-2011, 11:19 PM   #5
Location: Canandaigua,New York (The heart of the Finger Lakes)
We have the same problem in the Windjammer 3065, we just purchased 2 electric portable heaters. The furnace uses allot of propane on continuous use, so with the electric fire place (Built In)in the living room,plus electric heaters in the bedroom & hallway/bath area. We can keep the camper 72-degree's or warmer all the time. We went camping during the fall last year before putting it up for winter. We stayed cozy warm !
David & Annamarie & 2-Pugs (Fatty and Harley)
2011 Rockwood Windjammer 3065
2011 Ford F-250 6.2- V8
2011 Hensley Arrow "NO-SWAY" Hitch
BigRed is offline   Reply With Quote
Old 07-09-2011, 07:06 AM   #6
Wanna Be Camper
SaskCampers's Avatar
You could always look at putting a booster fan in the duct to the bedroom.
ef-series-duct-fan
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 07-10-2011, 09:54 AM   #7
hi all and thanks so much for your ideas!
Big Red, I notice that you have a Hensley Arrow No Sway Hitch. Does it work at good as they say? Our Windjammer 34ft pulls great until we encounter wind, and then it really moves. It is so bad at times, that it really wants to move the truck (F350) around. A bit of "white knuckling" in heavy winds. We have a Reese Cam Sway system installed, but it doesn't do the trick in winds
any thoughts?
Old 07-10-2011, 10:02 AM   #8
typical furnace fans are very low volume. It is simpe logic. Too big of ducts, insufficient flow. Larger volume fan will ure the prolem. Of course more air flow will create lower outlet temps.
Old 07-10-2011, 12:00 PM   #9
Herk7769's Avatar
The front heating ducts are in the floor registers. My Flagstaff has two. One in the hall floor and one in the bath. We had guests in the LR so closed the hall pleated panel and the bathroom "pocket" door. We froze our tails off. Our very next upgrade was:
Envi High-Efficiency Whole Room Electric Panel Heater - White (Model # HH1000) - eheat.com
Only 450 watts and it works great.
HAM CALLSIGN - KC3FFW
Old 07-10-2011, 01:31 PM   #10
DAISY BOYKIN's Avatar
Looks like between---------
Lou looks like between your 2010 and the 2011, Rockwood decided to save $$$$. I only have a floor vent in the hall just outside the bath door and two in the liveing and kitchen area. There is also a heat vent in the storage area under the bedroom.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
