12-06-2010, 08:26 PM
We have the unit scheduled to be taken in to the dealer to check this Thursday, 12/9/11. I will post the results.
12-06-2010, 08:53 PM
Sometimes that the best thing to do. Let us know what it is?
2010 wildcat 31ts
05 Ford F350 SD PS
12-06-2010, 09:22 PM
Full-Timer
What about tilt? When you were out in the wild were you level? Maybe something like a cable harness shifts into the cage or blades when you are leaning to the left for example.
2006 37' Toy Hauler
2008 Ram 2500HD 4WD, 6.7L CTD
Our Travel blog
12-07-2010, 10:52 AM
Location: Jacksonville Florida - Home of the Jaguars !!!!
This is why car antennas are now spiral wound, or otherwise not smooth, from whistling in the wind, and auto manufacturers test their creations in wind tunnels for noises and streamlining, too. It's a shame the heater manufacturer doesn't seem to think along those same lines!!! Randy
 '08 V-lite Flagstaff 30WRLS
'06 Ram 1500 QC hemi  Reese dual cam sway control,
K&N series 77 intake, Hellwig pro series helper spgs.
'04 Durango Limited Hemi, '72 Mach One 351 cj
12-23-2010, 09:37 AM
Update to problem:
According to our dealer, the problem with our furnace was that the shaft was never lubricated (presumably at the factory), so the dealer needed to strip down the whole furnace to be able to lubricate the shaft and bearings. So far so good!
By the way, we would like to give kudos to our dealer (Driftwood RV) for getting us in and out within a 2 week period so that we could make our holiday trip! Happy Holidays to all!
12-23-2010, 10:11 AM
Lou Amadio
I attached the troubleshooting guide for our furnace.
From what I see these are sealed motors and are not designed to be lubricated. I will have to look at mine (when it warms up!) and see if the shafts go through external bearings and not directly to the Cage fans.
If it turns out to be a permanent fix, I will have added a "new string to my bow." Keep us advised if the noise returns.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
03-16-2011, 01:47 PM
Kaz1
I am looking at buying a used Rockwood 2604 from Driftwood. I am curious about your experience with them has been to date??
-2009 Ford F-150, SuperCab w 8 ft bed
5.4L Screw, 3.73 rear, 8200 GVWR
-2011 Rockwood 2604, 2x6V Interstate U2200 batteries,Yamaha 2400 genny
-2011-23 nights
03-16-2011, 03:36 PM
Lou Amadio
I checked on that motor. Maintenance free brearings.
If the maintenance department eliminated the noise by oiling the shaft, it won't last long. They may have done you a favor in the short term by making the noise "go away", but it will be back as the oil drys up and you will be paying for a new motor next time.
It may very well be they needed to order the motor and could not guarrantee it would be ready by your departure time, so they "put a bandaid" on it.
04-02-2011, 09:57 PM
Unless this unit is still under warr
it sure sounds like it is getting tired
when the fan make a squealing noize means bearings are going
fix it shorty before it quits and you wont have heat
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 291 |
| 21 members and 270 guests |
| Areed411, bob34787, Buckeyecmpr, campfun, cardinal4fun, DAISY BOYKIN, darkcloud, deerslayer, digger47, Dunefam, lacroixyvon, Namchief, oldfordguy, patmo2000, patrapper, pier pressure, rockwood06, SinkorSwim, tentcamper1, T_LMurphy, walterw11 |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
