Old 05-02-2016, 07:00 PM   #1
Furnace Question on 2906WS
Have new 2906ws. I have 4 floor vents in the trailer, also under the sink their are 2 large grills 30 in by 17in. When the furnace runs, get very little air from floor vents, a lot of heat from the big grill under sink. Has anyone experienced this or have suggestions. Thanks.
Jim and Silene
2017 Rockwood 2906WS
2014 Dodge Ram 1500 Hemi 5.7
Firestone Airlift 1000, Equalizer Hitch
Augustpilot is offline   Reply With Quote
Old 05-02-2016, 07:23 PM   #2
fonzie's Avatar
I would take large grill out and check that furnace cover is installed properly, normally the large grill is the cold air return.....
Furnace help!!! Cherokee 27rk
Fonzie
Old 05-02-2016, 09:24 PM   #3
raspivey's Avatar
You've got a similar floor plan to what I just ordered. More than likely the same furnace setup. You shouldn't be getting anything from under the sink. Pretty sure you'll find something disconnected...ducting came loose or something. Should be easy to fix.
Old 05-03-2016, 09:16 PM   #4
Fixed
After opening the panel under sink I found the metal door open on end of furnace, allowing the heated air out the return under sink. Closed door, put the screw back in, now works well. Thanks for all replies
Jim and Silene
Old 05-07-2016, 10:55 AM   #5
We had the same issue. When dealer was working on other warranty items, he re-taped the ducts, and corrected a minor gas leak. When we get Steinbaum back, we'll look under the sink to be sure this isn't an issue, too.
Steinbaum is offline   Reply With Quote
Old 05-07-2016, 12:05 PM   #6
DaveSchwartz's Avatar
That's exactly the same issue I had (two's coincidence, three's a trend) - the screw holding the end on the plenum backed out and the spring-steel 'nut' fell off. Didn't find the 'nut' until after I had screwed the cover onto the plenum side with a self-tapping screw (it'll never come off again) but I also found one of the duct bayonet fittings was almost falling out and also took the opportunity to seal a lot of other leaky joints with Reflectix tape (the real duct tape).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
furnace
