11-28-2019, 10:37 AM
#21
Originally Posted by madatme
...the halloview camera just looks like its mounted there with no cover, is that correct...
The Haloview does have a cover, as you can see in the pics. I don't think it is extends far enough, fore or aft, past the camera. The one time I drove in the rain I did have water getting onto the lens. Before I use the TT in the spring I plan on shaping a larger piece of 16 gauge metal, shooting it with several coats of black rustoleum and epoxying it on top of the factory cover.
11-28-2019, 11:42 AM
#22
One comment and one suggestion:
Comment, no matter the cover over the camera, rain will swirl the the trailer draft and cause moisture on the camera lens.
Suggestion, a hood extension should be independent of the camera. The reason is that it may interfere with the rear view. If it is made to pivot off the top two screws, it can be adjusted up. We used Rear View Safety cameras and that is the way the hoods are attached. Aluminum would be a material of choice-easy to form and does not rust. When I did my mod, I painted the hood white. It does not absorb heat and the color blends with the TT.
11-29-2019, 10:02 AM
#23
Originally Posted by PenJoe
...one suggestion:
Thanks PenJoe. You've prompted me to re-consider. The OEM cover is separate from the camera but is pretty close and I had worried about blocking the lens if the extention I added was too long. Now thinking that fab'ing a whole new cover with extended coverage past the lens and longer legs would be a better solution. I could use the OEM one as a pattern. Thanks.
11-29-2019, 11:35 AM
#24
Trailer Park Supervisor
I think no matter what you do as Joe mentioned, water mist will cover it anyway. The nature of that location. You just like making stuff, lol.
Yes, I drink the water!
11-29-2019, 12:52 PM
#25
I do, I do. That's how I got into carpentry for a career. I have 4-5 projects going right now.
11-29-2019, 01:21 PM
#26
X2 on the Haloview being the better value for the money. One other point I'll put out there for those considering Furrion vs. Haloview is that you can buy individual parts with Haloview if something happens after your warranty has expired. Not so with Furrion. Stuck buying a new system (Camera/Monitor/etc as a package).
I bought one of the extension antenna's ($13) to replace the antenna on the camera and move it 16' further forward on my roof (34' toy hauler pulled by a crew cab) and totally eliminate any interference from other wifi sources when in a business are with alot of wifi around. Since then, I have no lag, hesitation or drop signal. LOVE HALOVIEW. Have also recently gotten the side view camera's that replace a marker light on each side of the camper so I can have a constant on view down each side AND the rear view. All active at the same time on a 9" screen.
https://www.haloview.com/pub/media/w...split-view.jpg
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
11-29-2019, 01:34 PM
#27
Rookie
I installed the Haloview mc5111 system at the dealer and it worked great during our trip home (at night). They sell an adapter plate so the camera can be mounted to the Furrion shark fin.
Haloview B-F02 Backup Camera Bracket Adapter Compatible with Furrion Pre-Wired RVs for Haloview MC5111/CA109 Camera https://www.amazon.com/dp/B07S...cm_..._BAb0Db3AXK5HV
2006 Chevy Trailblazer
2020 Geo Pro 16BHG
11-29-2019, 06:35 PM
#28
Mrprovy, that link is broken. I googled the description and it came up with the adaptor bracket that replaces the shark fin, when I got mine there were no holes that lined up with the shark fin plate holes, had to remove the whole shark fin. Which made sense anyhow, because I think it would stick out way too far if it was somehow mounted to the shark fin. I'd like to see a pic of what you did.
11-29-2019, 06:44 PM
#29
Rookie
2020 Geo Pro 16BHG
11-29-2019, 07:18 PM
#30
Haloview 7108 is on Black Friday sale right now for $197 on Amazon. That’s $145 cheaper than the Furrion
Just ordered it for Santa to give to me later this month
Mike
11-29-2019, 08:47 PM
#31
Thanks MrProvy, that one worked. But it's not compatible with my Haloview MC7108 camera anyway. Walaby that Haloview 7108 is about 300 bucks cheaper than the Furrion with 7" monitor. Good choice. Order the mount bracket too, but not the one Mrprovy linked to, that one is for a different cam.
11-29-2019, 09:23 PM
#32
Rookie
Np...sorry it didn't work, I found it to be such an easy connection.
This will be my next addition, I think they'll be a nice addition to the system.
Haloview CA112 Wireless RV Side Marker Light Cameras https://www.amazon.com/dp/B0818M1QLG..._TRC4DbMA30KTD
2020 Geo Pro 16BHG
11-29-2019, 09:45 PM
#33
None. There are better products available with better specs for half the price.
I agree. I don't even use my observation camera anymore. Drops out, pixilates, freezes up. Waste of money. Look elsewhere.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
11-29-2019, 10:43 PM
#34
Ordered the bracket that says it works with the 7108.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
11-29-2019, 11:16 PM
#35
Curious: What is the advantage to the side view cameras vs the mirrors on the TV? You should be able to see down the side of the trailer with the mirrors properly adjusted. Just wondering.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
11-30-2019, 08:43 AM
#36
Rookie
Jim M.
Parking up a curved driveway; I can keep an eye on the outside path without a spotter.
2020 Geo Pro 16BHG
12-01-2019, 05:42 PM
#37
Thats actually something that would be useful for me getting the trailer in the driveway. Thanks. I already have a Furrion camera that came with the trailer so I have to invest in the both the side markers and back up camera. Something to keep in mind down the road.
Jim M.
12-03-2019, 09:45 AM
#38
Happy Camper Take 2
I have a Furrion on my 5th wheel.. it tends to jiggle loose from the power connect, I have to unscrew reconnect and all works fine. Screen size is small so yes if you have the $$ get the larger screen. I really like mine when it works.
Happy Camper Take 2
2019 Ford F250 6.7L Power Stroke
2019 Rockwood Signature 8290BS 35' fifth wheel
12-03-2019, 09:52 AM
#39
Frog-Toberfest Organizer
I bought the Furrion at the Frog Rally this year for $250. The first one had reception issues so they sent me a replacement and it has worked very well on my 40' toy hauler. Haloview is a good one as well. Big Truck Big RV reviewed the Halo on Youtube and he liked it.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
12-05-2019, 08:12 PM
#40
Novice Travel Trailer Guy
Furion
But if you insisted on Furrion, go with the biggest screen you can afford. You'll shell out over 500 bucks for it on Amazon, the price came down, lol. Cheaper to just strap your old lady to the back ladder and stuff a walkie in her hand!
Bahabaha!
