Old 08-19-2016, 11:27 PM   #1
mgoodwin's Avatar
Galley gray tank - no monitor
We have a 2014 Rockwood 8280WS with the rear kitchen. One challenge we have encountered is the lack of a level monitor on the galley tank and having it surprise us by being full quicker than expected. Has anyone added a monitor or modified the existing panel?
Also, I have read that some people have installed a balance pipe between the two gray tanks. Does anyone know where to find info on what is needed to complete the job?
mgoodwin is offline   Reply With Quote
Old 08-21-2016, 06:47 AM   #2
Head Rambler
Are you sure that there isn't a button for the galley tank level on the control panel?
Most RV's with separate gray and galley tanks have separate buttons for each.
Some units also have a 'mini' panel near the kitchen just for the pump and galley tank level. It may be hidden in a cabinet.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 08-22-2016, 09:01 PM   #3
mgoodwin's Avatar
Nope, no button or switch on the panel and I looked inside all of the cupboards...nothing.
It's really kind of frustrating. Especially since I emailed Forest River about it and they did not reply.
Old 08-23-2016, 10:06 AM   #4
Head Rambler
I'd try emailing FR again and then I'd try calling them.
Since you have enclosed tanks, it's going to be kinda hard to look at them to see if the level probes are actually installed in the tank, but I think it's worth it to see.
If they are installed and there's wiring to them, then I'd trace the wiring as best I could and see if maybe the wrong monitor panel got installed.
Can you post a picture of the monitor panel?
Gotta go campin!
Old 08-23-2016, 07:22 PM   #5
mgoodwin's Avatar
Thanks Bama Rambler.
I plan to contact them again tomorrow.
This is the panel that I have.
What's also weird is that the panel 3 slide positions but we are only using 2, LR and Wardrobe (Which should have been installed in position 1 and 2, in my opinion)
Note there is only one gray tank button.
Old 08-23-2016, 07:42 PM   #6
Oaklevel's Avatar
After a while you get used to not having them. We do not use ours. Our older trailers did not come with the tank sensors.
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 08-23-2016, 07:49 PM   #7
mgoodwin's Avatar
Someone, and I'm not saying who, has a habit of using a little too much water in the kitchen sink. I was hoping a level monitor, along with my nagging, would help rectify that situation
Also, our front gray tank gets very little use. Only from washing our hands because we try to shower with local facilities if possible to save water. It would be great if we could join the two.
Old 08-24-2016, 12:12 PM   #8
Head Rambler
I'd try to find out if the sensors were installed.
Gotta go campin!
Old 08-24-2016, 12:15 PM   #9
TURBS's Avatar
Do you have one or two dump outlets?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 08-27-2016, 01:35 PM   #10
Looks like you only have one grey water, black, and fresh tank by the panel. So your shower, bathroom, and kitchen sink drain to one grey water tank. Unless you dry camp or don't have sewer hook ups, I usually just leave my grey water tank valve open. I have heavy water usage as well with 5 in family. My sensors also weren't reading right and with grey water about 1/3 to 1/2 full, poorer one cup of Cascade and one gallon of hot water into tank before road trip. Dumped when I arrived at destination. Sensor read correctly.
wingfield4601 is offline   Reply With Quote
tank
