Originally Posted by CHICKDOE
how is that black restraining strap attached? can you rotate it so that the nut and bolt are in the middle of the door opening rather than skewed to one side as the photo shows. if so i would think you can simply open the nut and bolt and pull the tank straight out with very little lifting. how are you trying to get it out now? lifting it up so the bottom clears the restraining strap? i may be wrong but it sure looks like it will pull straight out the door.
The bracket (retaining strap is heavy enough that you can't pull the bottle 'straight out the door' but it is flexible enough that when the retaining screw/wing nut is loosened, it pulls apart enough to get the bottle out.
There are 'legs' that go down from the strap and are screwed to the bottom plate. You can't get to these screws unless you remove the bottle but
you don't need to.
There is no need to cut anything, bend any lips or grind.
Simply remove the pigtail, remove the screw/wing nut from the retaining strap and tilt the bottle towards you and lift.
