08-24-2013, 09:43 AM
#21
i've had a Honda 3000 for about 10 years now and love it. Just recently started to use for boondocking. I keep it in the bed of my truck where my power cord can reach it. However, it is getting to be too heavy. If I did it again, I might buy the twin 2000's. Yesterday I added the remote starter to the generator and it works great.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
08-24-2013, 09:48 AM
#22
Originally Posted by Dennis and Julie
They won't run 2, should run one though.
And no microwave if the a/c is running!
08-24-2013, 09:53 AM
#23
I've run the micrwave with the a/c on the generator without any problems.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
08-24-2013, 08:02 PM
#24
Paul & Sheri
Originally Posted by dj3spots
Now i'm wondering if my 2 Hondas, running parallel, will power my 50 amp Salem Hemisphere 346 QBUD. It's got 2 ACs. Be happy if the one 15000BTU would run. Any input on this?
The max circuit breaker with two 2000i's is one 30 amp plug. That's all you'll get to the camper. You do have more capacity if you plug into one of the 10 amp plugs directly on the generator but a max total of 40 amps and 32 amps running. Check the rating and you probably can run one A/C on the 30amp circuit.
You would need two 3000's for 50 amps and now you're talking $4000 for two 130# units.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
08-24-2013, 08:26 PM
#25
I'll stick to my 2 little honda generators. Long as I can run the Keurig for morning tea. I'm good. Was curious. Will have to give it a go when the new camper comes in. It's taking forever to get here. Lol
08-26-2013, 05:26 PM
#26
i have a Hyundai 2000i. It ran great for a year then one hot day it ran my A/C for an hour or so and quit charging. Since then I have had to run to eight different service depots within 80 mile radius to find one that would service the unit. I know I am to blame for burning the unit output board but to not be able to get service really sucks!! Stick to a local dealer you can count on that will service it ASAP and not go through what I did....by the way, its been going on nine weeks now and its still at a shop 75 miles away
09-03-2013, 03:14 AM
#27
I had a Coleman 5000, which I gave to my brother up in N.Y., because they loose power at least two to three times a year where they are on Long Island. I wish I had kept it...I'm too darn nice. Anyway, I'll be in the market for another genny sometime early next year. My question, regarding the noise on the larger gennys, isn't there some kind of aftermarket muffler that can replace the factory muffler? One that will quiet the thing down by at least 50-60%?
09-03-2013, 10:36 AM
#28
nope, because they already have a quiet muffler and it's the engine noise that is so loud on cheap open-framed generators.
that's why generators like the Honda 2000 cost so much. it's more expensive to quiet the engine noise down.
only by building a noise box with fans, can you cut down the noise that comes out of these types of generators.
09-03-2013, 02:38 PM
#29
Well, that's rather disappointing. I really like the larger, open frame generators. When you state "engine noise", what exactly are you referring? The muffler is to dampen/quiet the noise that is created as a direct result of the combustion process. Now, remove any & all combustion noise, and what you have left are actual mechanical noises, ie., valves, springs, pistons, rods, etc., as they do their thing. If that's the noise which you refer, I can't imagine that noise would be so loud as to disturb the general tranquility of the average campground/secluded site....or am I mistaken?
I really think the combustion noise can be reduced a lot more, although it may require a custom fabricated muffler that actually incorporates a larger, heavier-duty style muffler, perhaps originally intended for a small automobile, or similar. It could be done, and shouldn't be that expensive, and any cost would be outweighed by the final result...a super-quiet open frame genny.
I'm not saying you're wrong, just saying that if they already use the quiet mufflers as you said, and I don't doubt you, that with a little creative thinking & mechanical aptitude, a lot more can be done to quiet the beasties down.
09-03-2013, 02:47 PM
#30
For years, people have been attempting to quiet those things with (so far) very little success. The only thing that seems to work at all is to enclose them in some sort of box. However, that introduces ventilation issues that need to be addressed.
You are much better off buying one that is reasonably quiet to begin with. You can find a Honda knockoff such as Champion, Kipor, Boily etc. for around $500.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
09-03-2013, 07:29 PM
#31
Agent86, i suggest you visit some of the Tech/Repair forums on other RV forums, especially RV.net's Tech Issues forum.
i've been reading questions/solutions like yours, for over 8 years, about quieting down generators like the Champion 3500.
there's a thread there, on Chinese generators, that is over 500 pages long with hundreds of posts about what you're asking.
