07-12-2012, 07:05 PM
Generator
Am looking to buy a champion generator 3500 watt rv for my 2304 mini light. Two questions has anyone had experience with these and the unit weighs about 100lbs has to go in back of truck anyone have any ideas or tricks for getting it in and out of truck without getting a hernia.
07-12-2012, 07:15 PM
I have a Black Max - 3650 running - 4550 starting - similar to the Champion Generator.
I have mainly used mine to run the A/C only and converter but nothing else and seems to work ok.
use two people to lift it into the truck or if you have a incline to minimizie the lifting height
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
07-12-2012, 08:51 PM
My only experience with Champion generators is hearing them in the campground and wanting to go throw it in the lake. They are LOUD; wake the dead loud. Your camping neighbors will thank you for buying a Honda or Yamaha. You'll be happier too.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
07-12-2012, 09:28 PM
Actually the are a pretty decent generator for the price. They are not as quiet as a Honda but they are definitely not wake the dead loud. I was pretty amazed how quiet they actually are. Its not any louder then my self contained Onan 4000. In my opinion they are well worth the money
07-12-2012, 09:42 PM
i'm still on the Lifan-Equipsource 2600 (2800 max) inverter/generator bandwagon.
68# w/ elec start, the size of a small suitcase, 58dB, has auto idle feature, easily pushes my 13,500 Dometic Brisk-Air.
at half speed (w/ AC on), runs abt 4 hrs on a 2 gallon tank.
i have run it over 300 hours since June 2011. just oil changes and a new spark plug (no valve adjustment yet). very impressive.
as low as $687 + $68 ship + no tax on internet.
'08-Rockwood 1809 Mini Lite
07-12-2012, 09:58 PM
I got a pair of Honda 2000. They are enough to run my air, or of I want to just run one of them, it will handle most everything else, but the air. They are light enough to tote around and store easy, I lifted my dads 3000 and couldn't stand up straight for two days, very well worth the $$$$, for my 2011 8285ws
Jack & Kim Blaydes
2018 Forester 3011DS
2011 Rockwood 8285WS (The Mobile Cabin) traded
2004 F350 SuperCab 6.0TD DRW (Mr. Duals) sold
07-12-2012, 10:32 PM
I looked at Champion 4000, Honda 2000i, and Yamaha 2000 or 2400. Long story short I went with the Champion. Yes it ran everything but it was like having a lawn mower running next to my trailer. We went camping with it for the first time and my Wife made me shut it off and return it to CW. I was able to return it to CW because I drained the oil and dried the gas tank. I then bit the bullet and upgraded to the Honda 2000i. Boy am I happy I did only wish I bought it first. I am not saying buy a Honda they are great but I think the Yamaha's are great as well. The key here is the inverter type. Not full speed direct drive like the Champion. Don't get me wrong they seem to be well built, but please don't be my neighbor at the campground. I also got my Honda 2000i (single) to start and cycle my 13,500 btu ac. All I did was add a Hard Start capacitor to the AC. Easy mod. The Champion inverter cubes just came out after I bought my Honda so I was not able to check them out. Sorry I went on and on.
2012 WindJammer 3006W
2013 Chevy Duramax 2500 HD LT Crew Cab Z71
2013 Chevy Suburan 2500 LT 4X2
Camping is my hobby
07-13-2012, 08:16 AM
You might want to try two smaller inverter generators hooked in parallel. The 2000 watt Champion 73536i weighs only 49 lbs., and has the same low noise spec as the Honda. I find that I can stand next to it and carry on a conversation in a normal tone of voice. Inside the RV, with door and windows closed, I can barely hear it.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
07-15-2012, 12:21 PM
We run to 2000i in parallel. We currently have a Rockwood 2607ss. The noise is minimal, starting is easy and the 30 amp plug is a plus. We also use these for the house when electricity is off. I've heard the Champion - no contest I much prefer the Honda. Not to mention the weight issue. Honda is much easier to handle.
07-16-2012, 04:48 PM
I did not think the 2000i was enough to start an A/C unit even with the hard start cap. This is goo news to me. I was thinking I HAD to get the 3000i or TWO 200 unit (run in parallel). Thanks for the info.
Brenda and John
Master Blaster of the Navy
07-16-2012, 05:03 PM
You may want to keep in mind the elevation you are at may make a difference. I live close to sea level, so what might work in San Francisco area may not work in Denver area. Just a thought.
Camping is my hobby
07-16-2012, 05:56 PM
Be loud and be proud....
I just purchased the Champion Generator and broke it in. I purchased it to use at home with the camper in case we lose our home power for an extended time. I will NOT be using this at a campground, just at home and boondocking with my friends.
Back to your question, get the wheel kit and a few 2x6's. You'll be just fine or buddy lift if you have to. Cabela's has the weekender kit at a good price and the wheel kit is inlcuded. It is a sturdy generator and will run everything if you need it to. When my kids go to college and i have cash to burn, then i will upgrade to the Yamaha's or Honda's, but not until then. It is just too much cash for as little as I plan on using it. Good luck and enjoy.
2012 Flagstaff 23lb Microlite
TV = 2003 Chevy Trailblazer EXT with 5.3 V8
Camper delivered 03-29-2011
Nights camped in 2011 = 17
Nights camped in 2012 = 4, 10 more planned
07-20-2012, 03:56 PM
Yeah, I had a Honda eu3000i, it took a crap, the est to fix was way to high, I ended up researching the Champion, and had it for over a month, and am very impressed. will run our Micro, and 13.5 a/c with no problem, but usually the tv a/c ect, For those Honda Lovers out there, please remember there are alternatives, and dont have to spend over a grand for another one! The 3500 is not much louder than the Honda I had, I was/am impressed with it! And a 2 year warranty to boot.
2007 Rockwood 8317ss Reese Dual cam sway, 2002 Ford Excursion XLT V10,Prodigy Brake controller
Married DW 03/15/97 3 kids
07-21-2012, 06:26 PM
I have the champion and I can't complain. I don't use it much but handles my 15,000 btu a/c and water heater in my 5th wheel. Can't run microwave too, but not an issue. I can buy a lot of champions before I spend enough to pay for a Honda. Light weight, easy to start you can't lose.
07-23-2012, 07:25 AM
I have the Champion 3500/4000. I lost my last TT in the TN floods in 2010. The generator had less than 20 hours on it at the time. It was submerged for 2 days. When we were allowed to recover our stuff from TT, it was covered in mud. I took it home and drained fuel, oil, changed plug and cleaned filter. It fired first pull and works like it did when new. We just used it last week on our trip to Iowa. It ran 24/7 in 95+ temps. I did learn it has the low oil shut off....at 2:00 in the morning. Great generator that you can hear, but not one to crank up in a campground.
2013 Palomino Sabre 34 TBOK
2011 Chevrolet Silverado 2500HD SRW CrewCab SB
B&W Companion
08-19-2013, 04:08 PM
Update, we lost power last month due to storms, we bugged out to the camper and the champion ran all night and we slept with the AC on.
So here's my take, get what you can afford and be appreciative when you really need it
08-19-2013, 04:14 PM
I've had my Champion for about 5 years now and it has NEVER let me down. I probably have about 500 hours on it easy. Many, many nights in Walmarts all over the place. Lots of time on it at the storage lot also. First or second pull no matter the weather, and I've used it in weather down below 0F. I only paid just a tad over 300 for it so at this point it owes me nothing.
I would not run mine in a CG. I have friends that have them and do, but I would not. Then again I don't often dry camp in CG's. However, when we winter camp, which is about 20 nights per year, if we lose power, then the champ will be coming life..
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
08-20-2013, 01:21 PM
Paul & Sheri
Same here so I can use only one unless I need to run the A/C (and they do work well for the A/C).
I originally bought the Honda 3000 and the next day I had the same concern as the original question here. How will I get the 135# unit out of the truck. I cancelled the order and bought the two EU2000I's for the same price and have 4000 watts. No regrets.
2012 F150 F/X 4, 6cyl EcoBoost with Max tow pkg
2013 Rockwood 8280WS 5th wheel
2006 Sunline T1950
2004 T@B T-16
08-24-2013, 09:33 AM
Now i'm wondering if my 2 Hondas, running parallel, will power my 50 amp Salem Hemisphere 346 QBUD. It's got 2 ACs. Be happy if the one 15000BTU would run. Any input on this?
08-24-2013, 09:35 AM
They won't run 2, should run one though.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
