Old 07-17-2015, 08:28 AM   #31
Originally Posted by strat56 View Post
I guess maybe I assumed because the companion model had a 30 amp outlet on it, it would supply 30 amps but I see from looking at the specs you are correct. 26.6 is still plenty to run an AC and some other things however.
Thank you for correcting me, I hate to give out incorrect information.
Yes 26.6 amps would run a 15kbtu ac with no problem. When I checked my Progressive 30 amp power manager it showed about a 13 to 14 amp draw while my 15 kbtu ac was running. Not sure what it draws at startup but you could easily have your TV, lights, etc. on at the same time.
Brewhedd is offline   Reply With Quote
Old 07-17-2015, 08:33 AM   #32
Herk7769's Avatar
I am sure someone mentioned it, but the weak point in a bumper mount is the bumper attachment welds and the tissue paper bumper itself:
ID:	83161   Click image for larger version
ID:	83162   Click image for larger version
ID:	83163   Click image for larger version
Old 07-17-2015, 10:15 AM   #33
No, I believe this is the first time I have seen it mentioned. I did notice it though. The square tubing bumper is about half the thickness of the square tubing I got to support the plate my generator is placed on. My welder overlapped the plate so it is also welded to the frame on that corner. This acts as a fish plate giving much more support.
I do think I am going to bring him back and have him add fish plates on the underside between the bumper and frame on that side. I then want the same thing done to the other side. Then the generator would have to tear the bumper in half to fall off, not very likely.
I considered placing a square tube inside the original bumper. This would add a lot of strength to the bumper but would not help the welds to the thin metal bumper itself. I could add a pipe inside it that fits snug but again, will not help the welds on the bumper. This would be a waist of time.
Got to look but may be able to weld a piece of angle iron across the two I beam frames underneath. Then add a fish plate from it to the two square tubes supporting the generator plate. Got to look underneath to see if enough of the frame is exposed to do this though. This would take a lot of the stress off the thin bumper.
Would have done this the first time but did not know how thin the bumper was!
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 07-17-2015, 10:20 AM   #34
oldtool2, the problem is the frame itself is also very thin (0.075") and is also a 3 pc welded design. Just not wise to add anything to the bumper or the frame itself.
5th wheel, generator, mount, wheel
