Old 11-08-2019, 11:37 AM   #1
Geo pro 19 FD
I’m in Tuscaloosa and tripped a breaker running a ceramic heater. I know others have used them, where should I plug it in?
Mclayton is offline   Reply With Quote
Old 11-08-2019, 05:01 PM   #2
bikendan's Avatar
You must have other things on 120v AC power, like the WH or fridge.
You need to assess what you have running on AC power.
Old 11-08-2019, 05:52 PM   #3
Flybob's Avatar
If Ceramic heater has dual settings, choose the lower setting and you will be fine. The breakers controlling the outlets in most TT are 15A. If there is anything else on that breaker, and you run it on Hi you will trip the breaker. Be aware if you run the microwave with the heater on you may trip the main breaker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-15-2019, 04:56 PM   #4
roadtrippyhippies's Avatar
We have a 19FBS and prefer our ceramic heater to the propane heater. We always plug it in in the bathroom since that outlet is a GFCI. The cord is long enough to pull it out in front of the couch and point straight at the bed to keep us warm. We left it on for days last winter and it has never tripped it. Good luck!
First time TT owners: 2018 Rockwood Geo Pro 19FBS
roadtrippyhippies is offline   Reply With Quote
Old 11-16-2019, 06:07 PM   #5
All your other 110VAC outlets are daisy-chained from the GFCI in your bathroom. The other outlets "probably" (i.e., should) have a sticker on them saying something like "GFCI protected outlet."
It's a crappy picture, but here's the outlet under my kitchen sink. It says "GFCI protected outlet" on the left side (GFCI in large letters). My actual GFCI outlet is in my bathroom, like yours.
Name:	GFCI Protected on 110VAC Outlet.png
So plug it in wherever you like.
2011 Traverse LT, 3.6L, FWD
Old 11-17-2019, 10:46 AM   #6
Trailer Park Supervisor
NJKris's Avatar
This is why I'm glad I got the optional heat strip for my A/C unit in my GeoPro. It is on a separate circuit from the outlets. Only worry is when I'm on shore power at home, I'm plugged into a 20 amp circuit. The heater alone draws about 14 amps. Gotta be careful what else you run at the same time or you trip the household breaker.
Yes, I drink the water!
NJKris is offline   Reply With Quote
geo pro
