Old 03-24-2019, 09:43 PM   #1
Geo Pro 19FBS Awning help
Okay. Geo Pro 19FBS with electric awning. I was told you can adjust one side to make it lower if needed. I cannot figure it out. There is a knob on each side, where the screw sits in a slotted piece. It is obvious to me that is what needs to slide but i cannot get it to slide and would rather ask then force it. Ideas? Thanks. No pics at the moment.
Buzz
2019 Geo Pro 19FBS / 07 4Runner
baseballbuzz is offline   Reply With Quote
Old 03-25-2019, 08:26 AM   #2
Loosen knob. Pull down on the awning on that side. Tighten the knob.
2011 Traverse LT, 3.6L, FWD
Old 03-25-2019, 10:02 AM   #3
thanks. i had tried that already but will try again. maybe just need a little more force.
Buzz
Old 03-25-2019, 11:01 PM   #4
Okay. figured out how to tilt my awning. can't believe i didn't figure it out before. the pic shows what i pulled on after loosening the knob. i always had the knob loose but was not pulling on the part circled.
Buzz
Old 03-25-2019, 11:38 PM   #5
Glad you figured it out. Now - you have to hope it will stay there. Mine seems to slip and an hour later, it's back up.
Old 03-26-2019, 12:36 PM   #6
Thumbs up
Thank you for posting the photo. I have the exact same trailer (even year and model) and got tired of trying to get help (even the dealership was stumped). I will try it when I get home from work.
HollySpringsDan is offline   Reply With Quote
Old 03-26-2019, 01:26 PM   #7
rsdata's Avatar
i believe with the screw knob loose, you then pull down on the end of the awning that you want lower... hold it there then tighten the knob... the slotted section will push in closer to the camper... not pull down on the elbow as you show in the picture
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 03-26-2019, 11:14 PM   #8
You are right in that the slotted section will push in closer to the camper. I should have been clearer. The part i have circled in yellow is what i pulled on toward the camper after the knob was loose, which allowed the slotted part to slide in towards the camper and then you tighten the knob. Thanks again to all.
Buzz
awning
