Old 09-08-2019, 08:29 PM   #1
Geo pro battery drain
I have a geo pro 19bh with factory solar. After just a few days of overcast weather, the batteries are down to 90%. The trailer is parked and not in use. The factory radio and LP detector are the only draws.
Question is: i pulled the fuses for the radio and LP detector on the converter.
Any advantages/drawbacks to this vs pulling the fuse for the battery at the converter ?
It appears the solar still is charging the batteries when I pulled the battery fuse.
I want the solar to keep the batts topped off, so I donít want to pull the negative lead from the batt until its winter storage time.
Thoughts?
Jdub is offline   Reply With Quote
Old 09-08-2019, 09:14 PM   #2
Disregard. The battery disconnect switch solved the drain from radio and LP detector. For some reason I thought it did not.
battery, drain, geo pro
