Old 05-05-2018, 05:32 AM   #41
stormer's Avatar
do not leave the campground with the water pressure left on. You just never know when something might start to leak... even under proper circumstances.
Well there’s a novel idea I hadnt thought about. Going to be away from RV for a few hours? Turn off water to RV? Thanks for that gem. Ive got my RV hooked up outside my house with water connected to it right now. Wondering if i should get out of bed and turn off the water. Ha.
James
James & Aimee
2018 Rockwood 2906WS
2012 Ram 2500HD 6.7L Cummins
Equal-i-zer 4 Point Hitch
stormer is offline   Reply With Quote
Old 05-05-2018, 08:05 AM   #42
Hamtown
Fmueller's Avatar
Years of reading forums say anywhere from 40 to 60 PSI.
Mine is set for 50.
Thank you. That’s about what thought.
Fmueller is offline   Reply With Quote
Old 05-05-2018, 06:41 PM   #43
bareftn's Avatar
I never ever leave the camper with out ALWAYS SHUTTING OFF THE WATER
bareftn is offline   Reply With Quote
Old 05-15-2018, 12:20 AM   #44
SYE
SYE's Avatar
I have never used a regulator, been camping for 40 years
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
SYE is offline   Reply With Quote
Old 05-15-2018, 03:29 AM   #45
Never had a particular problem (that know of anyway as always use the $8 camco brass regulator) but have instances where some water has sprayed back into rv due to poor fitting on water inlet. That's a pretty cheap piece of equipment
Old_hippies is offline   Reply With Quote
Old 05-15-2018, 06:12 AM   #46
water leaks are bad, just a matter of time before the damage shows up.
My filter ruptured while hooked up to the house! We were leaving the next day and had checked everything out before the trip. The next morning we woke up to water running out of the camper. Dried it up and hit the road. Needless to say over the next few months the floor started getting soft and bottom of cabinets started to swell. It was 2 months after my warranty ran out! Luckily my insurance covered the trip back to the factory in Indiana for the repairs . Water pressure had nothing to do with it! The POS filter housing cracked, no bad seal or loose,..cracked! I bypassed the filter the day we found it broke and will never put a filter inside my trailer again. 2013 Rockwood ROO iks231.
hughj555 is offline   Reply With Quote
Old 05-15-2018, 06:13 AM   #47
dcheatwood's Avatar
Glad you were able to enjoy the trip.
2018 Forester 3011 DS
Old 05-15-2018, 06:21 AM   #48
And as a public service reminder... because these boxes go down the road shaking and twisting every trip... do not leave the campground with the water pressure left on. You just never know when something might start to leak... even under proper circumstances.
Enjoy your new R/V!
X2 to never leave the rv for an extended time away. all those hoses and fittings could let go minutes after you leave. I always walk to post and turn the quarter turn valve off. I don't need to ever worry about coming home to a leak problem. now filling up the black tank and not paying attention to job at hand. that's another story for another post.
floridela is offline   Reply With Quote
Old 05-15-2018, 06:35 AM   #49
Arrow
...same here, though it's only been 4 : )
The Turners...
formerFR is offline   Reply With Quote
Old 05-15-2018, 07:12 AM   #50
I think the lesson here is never leave your trailer with the water tap opened and that is with or without a pressure regulator valve. When we leave for a visit or to shop, we always shut off the water valve because we never know when something will go wrong in a trailer or at the campground. I also removed the filter from inside the trailer and now it is outside on a rack.
Polariste is offline   Reply With Quote
Old 05-15-2018, 07:21 AM   #51
WolfWhistle's Avatar
Not to be outdone by all the pretty pictures... WW has one too
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 05-15-2018, 07:39 AM   #52
When we first started camping, I knew nothing about any of these issues. We had a 24-year-old trailer that I had purchased from my father-in-law. In 1979, we went to Flagstaff AZ to attend a planetary geology conference at the observatory and camped at the KOA. At that time, the campground water pressure was around 110 lbs. Being a raw newb with only dry camping experience I was completely ignorant about what equipment we needed. We left to go shopping and when we returned my neighbor came over and said he had turned the water off after our house developed a huge ballon (it was a regular, cheap garden hose - like I said, I was a newb) and almost burst when he caught it. He showed me the hose and it looked like something out of a cartoon. I bought a proper hose and a regulator on his recommendation. I was 26 at the time and newly married. Lesson learned. I've never been without one since.
2015 Palomino SolAire 20RBS
2022 Silverado 2500HD LT Duramax 4WD
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days; 2020: 0; 2021: 10 days.
elchilero53 is offline   Reply With Quote
Old 05-15-2018, 07:41 AM   #53
WPR
Just out of curiosity did you verify that the campgrounds water pressure was too high? Did you buy a regulator or check with a neighbor to verify that was the problem? Like others said it may not have been the source of the issue but simply a leak in the plumbing system. Needless to say regulators are still a good idea. Good thing the rig is still under warranty. Happy camping!
RobertJ is offline   Reply With Quote
Old 05-15-2018, 08:12 AM   #54
jtesta1's Avatar
Sounds more like a plumbing problem with water running out the threads. Sounds like it wasn't sealed sufficiently. But a good water regulator is definitely a must have . Also look under your sink to make sure water connections are tight. This is my second forest river trailer and both had leaky faucet connections.
jtesta1 is offline   Reply With Quote
Old 05-15-2018, 08:15 AM   #55
Red Wolf's Avatar
Originally Posted by mfeeley View Post
I removed my water filter all together and only use an external in-line filter now.
I did the same. Besides, Rockwood/FR put the filter where you couldn’t reach it. I had to pull the external shower housing to get to the filter to remove it.
Red Wolf is offline   Reply With Quote
Old 05-15-2018, 08:24 AM   #56
Same problem even with a regulator
I ha the same problem on my first trip out in my Rockwood mini light even though I had a regulator installed. The water filter housing was not tightened after the dealer winterized the system. So, when I connected the CG water supply, it flooded the bathroom and water filter compartment. Be sure to check that filter before connecting the CG water supply.
pt35cruiser is online now   Reply With Quote
Old 05-15-2018, 09:01 AM   #57
CaptnJohn's Avatar
When checking in at Ozark Country CG they tell you pressure is between 100-110 psi and to be sure to use a regulator.
1st mod, if an in house filter is to bypass it. Seen too many cause problems. Like asking for trouble.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 05-15-2018, 09:18 AM   #58
AquaMan's Avatar
Sye, at the Tadpole they had water pressure that was peaking around 100psi. I know at a place out west they had water pressure that would get up to around 130psi. They insisted that you had a regulator and they checked to make sure, even though they also had them on the bib.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 05-15-2018, 10:54 AM   #59
jkoenig24
ANYTIME you are away from your rig AND, no one else is there keeping an eye on things, the water supply should be shut OFF. Put a quarter-turn valve on the water supply and connect everything else to that. That way, it's VERY easy to turn the master water supply on and off. It sounds like a pain but, you'll quickly get in the habit of shutting the water off when leaving and back on when returning. The rig you save will be your own.
jkoenig24 is offline   Reply With Quote
Old 05-15-2018, 10:58 AM   #60
DouglasReid's Avatar
We use this method. The 1/4 turn is on a "Y" so we have a second water outlet to attach a hose for whatever.
It also allows us to relieve the pressure inside the hose and camper when disconnecting so the water is not spraying in our face as we unscrew the supply hose.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
pressure, water
