Old 05-27-2011, 09:02 AM   #11
I checked all of the 12volt fuses in the trailer (power center) They are the blade style and all looked good. It's 8:00am here now so I'm going to call the dealer and see if they can get me in quick so we can still go..
spawnman is offline   Reply With Quote
Old 05-27-2011, 09:06 AM   #12
I would say the fridge is DOA or maybe a power connection came loose in transit. (had this with my radio) The fridge should just work and is fairly simple to operate. If it's a local dealer see if you can talk them into an onsite service call. (never know) Good luck, maybe the dealer may have some tips!
brianb is offline   Reply With Quote
Old 05-27-2011, 09:06 AM   #13
hockeytownmom's Avatar
I Roo owner has a similar issue with the fridge.
Water heater & fridge
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 05-27-2011, 09:55 AM   #14
The trailer is new, but we've used it before on a few trips. The dealer said he could look at it but is swamped. I finally got the power module cover off of the outside portion and was able to check the two fuses that are on the control board. Both look good my multimeter is reading 0. (not sure if I'm using the meter correctly, googled and found some info.) I don't see anything in the power module area that would lend me to believe anything is loose.
For the fun of it, I tried running off of propane. Never heard it light. Have heard it before. I'm thinking it needs some power to be able to make the spark to light?
Old 05-27-2011, 10:02 AM   #15
Villa Estate 392FLFB
The_Stuff's Avatar
yup it needs to light to get going.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 05-27-2011, 10:51 AM   #16
MtnGuy's Avatar
Originally Posted by spawnman View Post
Ok, so the inline fuse reads 0 so that should be good. I looked at it and it says 250V at one end.
Many inline fuses that I have seen in 12 volt applications state 250 volts on the fuse. I have never seen 1 that doesn't have a clear glass middle, though.
You are correct, that you need 12 volt power for the propane spark, as well as the control board to send the signal.
Originally Posted by brianb View Post
I believe the fridge light only works when on shore power (120v) if I recall correctly.
The lite in the fridge should not need 120 volts to work.....that is part of the 12 volt side of the fridge, along with the control board so the fridge will work on propane only.
Old 06-01-2011, 12:55 PM   #17
Well we never made it out on the trip. Have an appt with the dealer on the 4th.
Thanks for all the help.
Spawnman
Old 06-10-2011, 08:43 AM   #18
Well I picked up the trailer yesterday from the dealer that thought I should share what they found.
So they said that in testing they found the 15amp fuse labeled fridg/furnace was blown. (Not sure how I missed that, I pulled and checked them all visually). Then then installed a 20amp fuse for testing and found it worked on propane. Turned then furnace on and it spiked to 17amps. Found that somewhere behind the fridge it the fridge and furnace were wired together. So the dealer rewired it and put the fridge and the furnace on separate fuses.
Not sure why this all worked for a couple of trips. Thinking back on the last trip before it stopped, the fridge was not getting as cold as it used to. Also noticed the heater was not getting as hot as before. So maybe this will have fixed all the issues.
Really not sure about the wiring of the fridge and the furnace to the same fuse though.
Spanwman
