Old 05-27-2011, 07:29 AM   #1
Getting ready for trip and no power to fridge
New Rockwood 2011 2604, getting ready to leave today and the fridge has no power. I checked the fuses in the trailer and all look good. Looked outside in the power area and unplugged it from the 12v. Looked at one inline fuse but can't tell if it's good or not, not even sure what kind of fuse it is. It's not clear to see anything. Checked the outlet the fridge plugs into and it appears to be a working outlet. All I see is one blue wire that is not going anywhere. Not sure if there is some place for it or not. Can't seem to remove the power module cover. Took the one screw out at the top but it won't come off. Not sure if there is more to check behind that or not. The cover of the module says to remove and check the fuses...
I have the Dometic DM2652
Any thoughts??
spawnman is offline   Reply With Quote
Old 05-27-2011, 07:34 AM   #2
MtnGuy's Avatar
1st question......does the light cut on when you open the door. If not, that is a 12 volt problem, and has nothing to do with the 120 volt side of things.
Old 05-27-2011, 07:35 AM   #3
No I have no light on in the fridge with the door open.
Old 05-27-2011, 07:46 AM   #4
MtnGuy's Avatar
Double check the power center fuses for the fridge. Unplug the fridge from the 120 volt receptacle for safety, for now. See if you can determine if the inline fuse is 12 volts of 120 volts, although I don't think systems would have a 120 volt fuse like that. Since you don't know if that fuse is good or not, pull it and replace. Still with the 120 volt side down, see if you are getting 12 volts to that fuse. If not, it has to be at the power center.
Old 05-27-2011, 07:55 AM   #5
When you say the power center fuses, are you talking about the 15amp fuses in the trailer? if so I checked all of those and they look good.
As far as the inline fust, I don't have any extra's now and would have to make a run to the store to get one. I'm sure it's stamped on the fuse somewhere with the voltage?
Old 05-27-2011, 07:58 AM   #6
Grumpy Old Member
ChrisZazzara's Avatar
You might want to check the fuse with a meter, sometimes the will look OK but still show nearly and open when instpected.
ChrisZazzara is offline   Reply With Quote
Old 05-27-2011, 08:48 AM   #7
Ok, so the inline fuse reads 0 so that should be good. I looked at it and it says 250V at one end. I've attached a couple of pics
ID:	5999   Click image for larger version
Old 05-27-2011, 08:48 AM   #8
I believe the 2652 has the following hook-ups - 12V, 120V, and LP. The 12v is only used for the controller, and LP/120V is used for cooling. If you are getting no response from the buttons and lights above the fridge focus on your 12V power. I believe the fridge light only works when on shore power (120v) if I recall correctly.
brianb is offline   Reply With Quote
Old 05-27-2011, 08:50 AM   #9
So I am on shore power right now. Microwave has power and the battery's are reading full so it appears to be charging.
Old 05-27-2011, 08:55 AM   #10
Ok, so the power center should also be supplying 12 volt power to the rig (for lights, radio, fridge, etc.) You should be able to click the fridge controls and get some life (lights lighting up). If not open your power center access door and check your 12 volt fuses. They should have labeled the one for the fridge. It's a blade style fuse.
