Old 10-22-2015, 01:28 PM   #1
jerbo9
GFCI shore power problem
Hi, I just joined the forum and have a 2008 Rockwood 8288SS 5th wheel. I have plugged the RV into the same GFCI outlet w/o problem until yesterday. Now every time I plug it in, it trips the gfci. I installed a new gfci, but had the same problem.
I tried it on a different gfci outlet and it did the same thing. However I can use a normal outlet w/o any problem, i.e. it provides power to the rv w/o tripping any c/b's.
I would appreciate any ideas of what the problem could be and a fix.
Thanks in advance....
jerbo9 is offline   Reply With Quote
Old 10-22-2015, 01:42 PM   #2
Bluepill's Avatar
Sounds like the GFCI is working properly and has detected a ground fault. I suggest you Google Ground Fault for methods of tracking it down.
Old 10-22-2015, 02:31 PM   #3
TURBS's Avatar
I wouldn't suggest plugging your camper into a gfci anyway.
Plug it into the normal outlet or put a normal outlet in.
Sometimes gfci receptacles don't play nice with campers.
TURBS
2008 duramax
2015 columbus 320RS
2015 camping "31 nights"
Old 10-22-2015, 03:27 PM   #4
Fivealive's Avatar
TURBS
2008 duramax
2015 columbus 320RS
X2 Not required and a potential nuisance.
Fivealive is offline   Reply With Quote
Old 10-22-2015, 03:55 PM   #5
fonzie's Avatar
This is just a suggestion: completely disconnect your water heater (remove supply wires) and then plug your trailer into the GFCI again and see if it trips......on occasion the water heater element has burnt out and is tracking thus tripping GFCI....and it will not trip on a regular breaker.
Fonzie
Old 10-22-2015, 04:43 PM   #6
jerbo9
Hey, this forum is ok. Thanks for all the replies and suggestions. I did some trouble shooting by flipping off all of the RV circuits breakers and turning back on one at a time. When I turned on a c/b labeled "opt water hrt" it tripped the gfci. I think Fonzie hit the nail on the head and I'm going to order a new element. Also thanks for advising that a gfci outlet is not required but it is outside near a faucet so it will stay and hopefully the element will solve the problem.Again, Thanks..
Old 10-23-2015, 05:56 PM   #7
BillyBass's Avatar
I had a 2001 Keystone Lite House.I plug in to the regular plug and it keep on kickin .I found out my plug on the end was bad.By coming back home plugin in to a ground fault and it kick so I change the end and didn't have any other problem with it. Good Luck
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 10-23-2015, 06:00 PM   #8
Who Dares, Wins
doc73's Avatar
Depending on your heater might be able to get the element at Lowes or HD. Burned mine up once and got it in the heating isle. Just make sure to get the 120 version not the 220.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
power
