Old 01-13-2012, 01:26 PM   #1
johntoye's Avatar
Grey Water Buttons on Control Panel
I have 2 grey water level buttons on the control panel of my Rockwood 8315BSS but the manual states one one grey water tank. Any reason for the two buttons?
Thanks,
John & Tara Toye
2011 Forest River Rockwood Signature Ultra Lite 8315BSS
2013 Chevy Avalanche
johntoye is offline   Reply With Quote
Old 01-13-2012, 02:27 PM   #2
One will be for the galley gray water tank(for the kitchen),the other one is for the bathroom gray water tank.
09grizzly1
09grizzly1 is offline   Reply With Quote
Old 01-13-2012, 02:33 PM   #3
johntoye's Avatar
Thank you. So they count both tanks as 1?
John & Tara Toye
Old 01-13-2012, 02:52 PM   #4
realebill's Avatar
no,the 8315 has 2 gray water tanks and there are separate dump valves for each one. manual is pretty basic and info in it does not pertain to all models
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 01-13-2012, 03:08 PM   #5
johntoye's Avatar
Thank you realbill. I will crawl under tonight to check it out. I was under the impression that there was only one tank! Thanks again,
John & Tara Toye
Old 01-13-2012, 07:05 PM   #6
They list the gray water tanks as 76 gal,when in fact there are 2 38 gal tanks.
09grizzly1
Old 01-16-2012, 06:06 PM   #7
Thanks,
Our 2010 8315BSS actually only has one grey water holding tank, however the control panel indicates that there are two tanks which makes it look like there is a separate galley holding tank. The indicator button labelled "Galley" doesn't actually do anything. The same indicator panel is used by Forest River in different model trailers, some of which do have two holding tanks. The trailers that have two grey water tanks usually also have separate drain dump valves, one in the vicinity of the galley and the other in the vicinity of the bathroom/shower section of the trailer.
...VTX-AL
VTX Al is online now   Reply With Quote
Old 01-17-2012, 09:35 AM   #8
johntoye's Avatar
Thank you VTX-AL
John & Tara Toye
