Old 08-24-2016, 05:51 PM   #1
Gross axle weight
How do I measure the actual gross axle weights of my 2016 F150 once my trailer is hitched up? I know that the front GAWR is 3,525 and the rear GAWR is 3,800 but not sure if I am exceeding the limits. I would be towing a Rockwood 2702 ws. Thank you.
dernst is offline   Reply With Quote
Old 08-24-2016, 05:56 PM   #2
CAT scale at most truck stops.
BIRDS AREN’T REAL
emm-dee is offline   Reply With Quote
Old 08-24-2016, 05:57 PM   #3
You need to find a truck scale like CAT. It will have at least 3 sections to the scale so you can measure the weight of both the truck axles and the trailer axels separately
Ontario
Current: 2019 Sunseeker 2290S
Happy Vibe is offline   Reply With Quote
Old 08-24-2016, 06:00 PM   #4
CWSWine's Avatar
Pull it on the CAT scales hooked up to the RV. You will get 3 different weights: Front Axle - Rear Axle - Trailer Axle. The rear axle weights should not exceed the weight posted on your door jam on the silver color sticker. You should also add your front axle and rear axle together and that shouldn't exceed the GVWR listed on the same sticker. The weight on the trailer axle should not exceed the GVWR of the RV listed on the front left side of the RV.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 08-24-2016, 06:42 PM   #5
The GVWR on the camper is for the whole camper... not just the weight on the trailer axles. The tongue weight needs to be included too.
The weight on the trailer axle(s) should not exceed the GAWR of the axle(s).
Sent from my iPhone using Tapatalk
325BH is offline   Reply With Quote
Old 08-26-2016, 09:53 AM   #6
CWSWine's Avatar
You are correct. What I should of said is look at the axle rating on the sticker on the left forward side the RV and get the axle ratings. Say you have two 6000 lbs axle insure the RV axles are below 12,000lbs scale weight..
Old 08-26-2016, 10:09 AM   #7
Check this out..
https://catscale.com/how-to-weigh/
https://youtu.be/ixK9BTAXqyY
dalford is online now   Reply With Quote
Old 08-26-2016, 10:13 AM   #8
CWSWine's Avatar
This is a great video on weights and how they relate to each other. You will learn how to match your truck to your RV.
Matching Trucks to Trailers
Safety is critical when towing an RV Trailer. This training video discusses the importance of understanding a Truck's ratings and how these ratings limit the size of the trailer that can be safely towed. You will be provided the tools and basic understanding needed to assist your endeavor to properly m
axle, weight
