06-06-2017, 07:03 AM
#41
Originally Posted by Stew_Pudaso
I've only used mine a handful of times so far. It's been great and the trailer is so much more stable. Hopefully it lasts.
Thanks to you also Stew! I LIKE the part about More Stable,! Youroo!!
06-06-2017, 12:55 PM
#42
Originally Posted by Windjammingnc
I have to admit that it's working better than I thought. Once I recalibrated the level point, it's been nearly perfect every time. Changing tires is a breeze and not having to carry a hydraulic Jack with us is a blessing.
You do have to get the trailer within about 1 degree of level before using the system or else the tires on the low side will end up completely off the ground.
I've never used an auto level system but is tires off the ground a negative thing? I see 5th wheels with 2 tires off the ground all the time.
2008 Toyota Sequoia SR5 5.7L 10k tow package
2017 Rockwood 2702WS
Equal-i-zer 4 point, Prodigy 3 brake controller
2016 nights camped = 17
2017 nights camped = 4
06-06-2017, 01:20 PM
#44
Our windjammer is coming with the GC TT and we pick ours up in 6 weeks. Looking forward to seeing how it works. Even with all the TTs at the RV Show (largest in NC) this past weekend, we didn't see it on a single unit. Only on 5th wheels.
We have the level system on our 3029W WJ, works great. Pull in, unhook from TV, push auto level, 3-5 mins level, then slides out.
2017 Windjammer 3029W
2016 F150 Eco Boost
McKinney TX
06-06-2017, 01:34 PM
#45
The whole purpose of putting wheel chocks on tires is too prevent rolling. I then tires are off the ground, you lose some of that resistance.
They leveling jacks would be damaged in my opinion if they were subjected to strong lateral forces.
I would only used the jacks to raise the tires if the trailer were connected to the tow vehicle with emergency brake set.
Paul and Angela
Raleigh, NC
2018 Windjammer 3008w
06-06-2017, 01:36 PM
#46
Our dealer actually indicated that you should auto level with the slides out since that way you get final level since extending the slides after level could cause an unlevel situation, especially on softer ground
Paul and Angela
Raleigh, NC
06-06-2017, 02:24 PM
#47
My response: What does the manual say? Dealers are very often known to be ignorant and give bad advice.
2011 Traverse LT, 3.6L, FWD
06-06-2017, 05:34 PM
#48
The Rockwood manual makes no mention of the auto level system.
I don't recall any mention in the Auto-Level manual either
Paul and Angela
Raleigh, NC
06-08-2017, 10:57 PM
#50
We just bought an 8327ss with the 4.0 leveling system as an upgrade from our Summerland bh. I brought it home and took it directly to a local campground right down the road from our house to shake it down for the weekend. Have taken it on our first camping trip to the beach with it and WOW!!!!! is all I can say. The system works as advertised. Mind you, you still need to be fairly level, you can't park it on a hill side and expect it to level it for you, but most sites we camp at are going to be level enough. I unhook from the truck, turn it on and hit the level button. I just sit back and watch it do its thing, takes a few minutes but after it is done the trailer is rock solid. I don't need x chocks or braces or any thing else to get rid of the wobble in the camper, don't have to tighten the scissor jacks daily like I used to. Plus, when its time to leave, I hit the retract button and it brings the jack back to the height that I unhooked from and its ready for me to hook back up. Definitely recommend
06-16-2017, 08:25 AM
#51
After looking at several 8328BS's , we decided on a 2018 that was just delivered to a dealer in Michigan. It came with the new 4.0 leveling system, I was sceptical at first, but so far this system is great. The dealer's walk through insturustion was to park as level as possible and to chock the tires, so that the trailer doesn't roll, unhook the tow vehicle, turn on the panel, push the auto button and stand back. So fare it has worked flawlessly. Forest River has really stepped up there game, good job!
2022 Rockwood 8328BS
2019 Ford F150 Ecoboost Super Crew
06-16-2017, 08:44 AM
#52
Agreed. The stability was also a big plus for us. I'm a big guy and I can walk around with rocking the entire trailer.
2007 Rockwood 8318ss
2018 Rockwood 8324bs (on order)
Camping in Northern Michigan!
06-16-2017, 08:50 AM
#53
We notice most shaking in the trailer when the wheels are still on the ground. Once we get sites that are skewed slightly and get a set of wheels off the ground it really feels much better. It does get a few looks when people notice the jack is not on the ground and they think it's sitting on normal stabilizers in a TT.
2018 Rockwood Signature Ultralight 8329SS
07-07-2017, 07:44 PM
#54
MicroLite
Has anyone out there put the Ground Control TT leveling system on a Microlite?
I have a 2015 25KS and am very close to trying this system.
07-07-2017, 09:33 PM
#55
If it is not an option from the factory now the frame may be too light and subject to twist. If it is an option, check to make sure they did not upgrade the frame now for the option.
A neighbor was looking at a Rockwood ultralite TT and was told not available but is on the Signature series.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
08-12-2017, 05:08 PM
#56
We have a 2018 Rockwood 8328bs on order, with all of the praise for the Auto level system we ordered ours with it.
08-15-2017, 09:46 AM
#57
Contacted Lippert and they said it will work on my Micro Lite.
Will not twist frame due to the jacks raising together and not individually.
11-28-2017, 12:13 PM
#58
Removed from Windjammer?
I noticed that the Windjammer line has been updated for 2018.5 models (completely new model numbers and lineup) and one of the casualties appears to the the Ground Control TT is no longer an option.
Haven't checked other Rockwood lines to see if it's still offered or not.
11-28-2017, 02:18 PM
#59
My 2018 Rockwood Signature Ultra Lite came with one !
2016 Chevrolet Silverado 2500HD LTZ Z92
2018 Rockwood Signature Ultra Lite 8311WS
11-28-2017, 02:22 PM
#60
We got it in our 2018 Windjammer but it was listed as an option when we ordered it in the spring. It's still listed on the Signature ultra lite page but no longer on the Windjammer page.
Paul and Angela
Raleigh, NC
