Old 08-12-2016, 09:26 AM   #1
Ground Control TT Auto Leveling now available
I have been reading what limited info has been available this year and it appears FR/Rockwood will be the first OEM to offer it on their travel trailers (at least a couple of models for now). Would you go for it on a travel trailer?
Forest River Trailers Offer Lippert Ground Control | RV Business
2016 Coachmen Freedom Express Liberty Edition 322RLDS (Sold)
2017 (SOB) Jayco Eagle 330RSTS
2015 GMC Sierra 2500HD SLE Gasser
blujay40 is offline   Reply With Quote
Old 08-12-2016, 09:51 AM   #2
ryand's Avatar
I think its a good idea for the largest market of RV's sold....TT's. I am shocked it hasn't happened sooner. However, The LCI tongue jack failure rate around here on this forum (one myself) leads me to believe that there will be issues.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 08-12-2016, 10:18 AM   #3
gectisme's Avatar
Very cool, probably old news to RV'ers who have been doing this for awhile, but I didn't know about those systems. My Wife and I were watching a RV pull next to us a few weeks ago and all they did was park and those auto levelers came out, then the slides and they were done in about 5 minutes. I was thinking boy, wish we had those! I figured it was for RV's only or they would have offered it at least as an option. I am sure a retro-fit will be out of our budget though...
Thanks for the article.
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
gectisme is online now   Reply With Quote
Old 08-12-2016, 10:52 AM   #4
(Dry Huunday)
DreiHunde's Avatar
OK. Take my money
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 08-12-2016, 12:20 PM   #5
Good idea. Note the video illustrates you must have at lease a 10 inch frame to start with. Also back in 06 we had a Jayco Eagle 322FKS trailer that I could easily twist the 10 inch frame if I wasn't careful when raising the stabilizers. I found out because the doors would stick and cabinets would hardly open if I had one side a little higher than the other.
Use care & good luck.
billb800si is offline   Reply With Quote
Old 08-12-2016, 12:51 PM   #6
CaptnJohn's Avatar
Different than stabilizers ~~ they stabilize and level at the push of a button. I have auto-level on the 5er and would never consider any until without it in the future. Less expensive if added at the factory.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 08-12-2016, 01:16 PM   #7
True but remember 5ers have a bigger frame than trailers to start with. Also not all 10 inch trailer frames are of the same caliber (some I-Beams some rolled steel)
Happy trails,
Old 08-12-2016, 01:55 PM   #8
TT, 5th wheels, pop ups and motorhomes are all RV's. I assume your talking about motorhomes?
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
Old 08-12-2016, 02:40 PM   #9
I looked at the video. Pretty slick. But I wonder how this would work on my TT. After manual leveling and putting out slides, I am about 1 1/2 inch off level toward the slides.
So, I to make level, I add a 2X8 under each slide side tire before leveling/stabilizing to start. I wonder if they have something built in for making an off level adjustment before beginning. But of course, how expensive after market. On my previous motorhome I had a power leveling system (not auto), that I could push buttons to make fine adjustments after final leveling.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 08-12-2016, 02:52 PM   #10
CaptnJohn's Avatar
After auto-level does it's thing if your slides put you out a little simply hit it again or manually adjust. Only takes seconds...
2016 F350 diesel
leveling
