Old 05-31-2014, 08:54 PM   #21
Originally Posted by Weezer View Post
...But, I can't make that king pin and/or ladder mod for the satellite dish.
Pin box holder for Tailgater was easy as I can mig weld. The ladder mount was a little different as I had to call in reinforcements, i.e. our oldest son who is the expert aluminum tig welder. If it's alum, I make the parts and he welds it.
Old 05-31-2014, 09:08 PM   #22
Send a message via AIM to jk31668
do they work on motorhomes with dual rear wheels?
2010 sunseeker 3100ss
jk31668 is online now   Reply With Quote
Old 05-31-2014, 09:14 PM   #23
I suppose if you had enough of them as they are not but about 6" wide, so it would take at least 4 or 6 for a mh
Old 05-31-2014, 09:22 PM   #24
10x
Cool
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 05-31-2014, 09:33 PM   #25
BamaBob's Avatar
Originally Posted by OldCoot View Post
Don't think my mod will make any difference, as you have to use the levelers before you use the Bal X Chocks and the levelers are under the tires. Don't really understand the concern. I guess I'm just dense.
Not Dense my friend - I dunna get it either - it should work
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 06-10-2014, 02:57 PM   #26
BruceM's Avatar
Just got 2 sets of these but have not had a chance to use them yet.
Our trailer is a 2109S and there is 2.5" between the tires.
I had to trim 2" off one of the Andersons in order to barely get it to fit between the tires.
I cut off the tip end, as recommended by Anderson. I didn't see how cutting anything off the other end was going to be of any benefit.
I did a 45 deg cut using my table saw.
This will give one tire a steeper ramp than the other.
We will see how it works out in a few days when we start our maiden voyage with our new camper up to the Olympic Peninsula.
2015 Rockwood MiniLite 2109S
2018 Ford F150, 3.5L ecoboost
Blue Ox SwayPro hitch
BruceM is offline   Reply With Quote
Old 06-10-2014, 03:08 PM   #27
If you look at the picture of mine going between the tires, you can see that cutting a 45degree on the bottom corner will let the Anderson in between the tires.
Name:	Anderson Leveler corner.jpg
Old 06-10-2014, 05:30 PM   #28
BruceM's Avatar
I can not set mine up between the tires like that.
There is only 2.5" between my tires.
I set it on the ground behind the tire.
Old 06-10-2014, 05:37 PM   #29
I couldn't either, I only have 2-7/8" between them which is why I cut the corner off.
