Old 10-30-2017, 04:48 PM   #1
Height of camper
My Rockwood 2604WS is rated at 11'2" height. I need to go through a door (storage barn) that is 11'6" BUT the door is at the top of a ramp.
Does the stated height of the camper INCLUDE the A/C and Maxxaire covers?
Will the ramp prevent entrance? (I did NOT do well with math formulas)
Ignotum per ignotius
DanG Campers is offline   Reply With Quote
Old 10-30-2017, 05:05 PM   #2
A32Deuce's Avatar
Can you back in?
A32Deuce is offline   Reply With Quote
Old 10-30-2017, 05:27 PM   #3
If the A/C and Maxxaire are standard equipment, usually the height would include those items. If those items are optional you should check the total height to be sure. I would check to be sure anyhow. Don't assume it's OK.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
rskeans is offline   Reply With Quote
Old 10-30-2017, 06:21 PM   #4
Do you have a ladder on your rig?
Get another person to help... will be alot easier.
If you have the ladder, go up with something long and flat, lay the stick, or piece of wood across whatever sticks up the highest on your camper, ac unit or maxair vent cover, have the piece you use long enough to hang out over the side of the camper and use a measuring tape to get an accurate height measurement.
Just measure from that stick to the ground.
That way you know exactly how high your camper is.
6CatDaddy is offline   Reply With Quote
Old 10-30-2017, 06:43 PM   #5
llr
How close is the ramp to the door? Are you pulling in or backing in? If the ramp is close and you are backing in it could be an issue even if the hieght is ok
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 10-30-2017, 06:52 PM   #6
Also depends upon ramp angle and camper angle to vehicle. Can't assume it is level. Too many variables! Door measurement may not be accurate either.
Need to back it up with assistance to visually check.
2018 Micro Lite 21DS (New Style Front)
2016 Toyota Tundra Dbl. Cab Limited 4x4 5.7L
sportbikenut is offline   Reply With Quote
Old 10-30-2017, 08:40 PM   #7
No.
Old 10-30-2017, 08:41 PM   #8
Great idea!
Old 10-30-2017, 08:45 PM   #9
The ramp is steep and ends shortly before the door. The door is into a large coliseums at a fairgrounds. Lots of campers winter there but I am cautious. I will be able to pull it in and out. The building is huge. I like the idea of measuring with the pole. Going to give it a try. Thanks, all!
Old 10-30-2017, 08:54 PM   #10
May seem like a silly ideal to some , BUT there are times when less than an inch can be acquired simply by lowering the air pressure in the tires and especially if only for a minimal distance, then air the tires back up once inside.
Don't forget to reverse the procedure when removing from the barn
extxn is offline   Reply With Quote
Old 10-31-2017, 07:38 PM   #11
There have been several threads here where the height did not match what the manufacturer said it was.
The only way to truly know your height is to go out and measure it.
2011 Traverse LT, 3.6L, FWD
camper
