Old 05-23-2012, 07:32 PM   #1
F22
F22's Avatar
Help - "Battery Disconnect" on Mini-Lite -- what does it control?
We have a 2012 Mini-Lite 2109S, and are getting ready to leave tomorrow sometime for a Memorial Day weekend campout. This will be our first trip with this new TT, so I am still figuring some things out.
Below is a pic of a push-pull switch labelled "Battery Disconnect" that is below the refrigerator on the back wall. It definitely is not a real battery disconnect, as so far, I have been unable to determine what if any electrical items that it shuts off the power to. And I don't know if it does happen to kill the power to something, whether on is out or in. I can't find anything in my Owner's Manual about it.
For anyone with a Mini-Lite that has one of these switches pictured below, could you please tell me what it does, or is supposed to do, and which way is on or off, in or out? Thanks in advance for any input!
F22 is offline   Reply With Quote
Old 05-23-2012, 07:45 PM   #2
sherdep's Avatar
someone with a 2012 will have to help or verify what info I am posting
my 2011 2306 did not come with this option - which is new for 2012 models.
If I am not mistaken - pulled out is off and pushed in is on - and it does just what it says - disconnects the battery so it will not drain the battery when the camper is in storage for extended periods of time.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-23-2012, 07:49 PM   #3
TURBS's Avatar
If you are still HOOKED to shore power when you use the disconnect EVERYTHING will still work .
until you unplug from shore power .
Old 05-23-2012, 10:41 PM   #4
F22
F22's Avatar
OK, that explains it. I had thought that even when on shore power, that because the lights are 12V, the switch should kill them. But now I understand how they wired it.
On ours:
Out is ON,
IN is OFF
Thanks everyone!
Old 05-23-2012, 11:38 PM   #5
Terier's Avatar
I had that style of battery disconnect knob installed on the outside of my trailer near the battery box. On my trailer the knob pushed "In"= off and pushed "Out"= on.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
Old 05-24-2012, 05:43 AM   #6
Witch Doctor's Avatar
Pull it out for your battery power, and push it in to disconnect. It kinda the opp. of what you think, I have to watch how I store things around it so a shift of anything next to it will not disconnect my power while traveling. You would think that it should be in for power out for disconnect.
Old 05-24-2012, 06:10 AM   #7
sail2liv's Avatar
Factory Batt switch
On my TT I use to have the TV would not charge the batteries if it was not in the on position.......not sure if that applies to the converter also?
Good luck
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 05-24-2012, 06:29 AM   #8
TURBS's Avatar
On ours:
Out is ON,
IN is OFF
Thanks everyone!
No worries!
I wondered if it still was plugged in.
We all loose our minds once and awhile.
Have a great day.
Old 05-25-2012, 04:45 PM   #9
I have a 2012 Rockwood 2109S and if you are disconnected from shore power, this will disconnect the battery from all 12vdc loads to prevent the battery from discharging over a period of time due to the parasitic loads.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 06-04-2012, 01:33 PM   #10
Colonel
If I turn off the battery disconnect while traveling, wouldn't the electric from the battery run the fridge? Doesn't the battery charge while connected to the TV while traveling? Is this right, would it not drain my battery?
Thanks to all replies.
colonel134 is offline   Reply With Quote
Old 06-04-2012, 01:39 PM   #11
Triguy's Avatar
You would leave the batteries connected while traveling. The disconnect is only for extended periods when you don't want the batteries drained due to the parasitic loads.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-04-2012, 11:34 PM   #12
Colonel
Propane versus battery disconnect
I understand that. I have an unanswered question.
1) Other posters say they used propane to run the fridge while traveling. If I turn off the battery disconnect, would the fridge use the battery versus using propane while traveling?
Old 06-05-2012, 05:17 AM   #13
The refrigerator requires 12 volt (battery) power to work. This powers the control circuit even if the fuel source is propane. Most newer fridges are either propane or 120 volt (shore) power. Switch selects "gas " or "auto " (which is shore power if available and gas if not) . Either way, 12 volt power is required.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 06-05-2012, 06:56 AM   #14
Triguy's Avatar
I get that now. It wasn't clear to me what you were trying to do.
As mentioned above, you will need 12VDC even while cooling with propane. You probably have a two-way fridge and have no option to use the battery alone.
As an aside, the only fridge that can use 12VDC, AC, or propane (three way fridges) are generally used in Popup campers. FWIW- the 12VDC in a three-way is used only while towing to maintain coolness in an already cold fridge.
Scott
2012 Shamrock 233S
Old 06-05-2012, 07:25 AM   #15
TURBS's Avatar
You can only use propane while driving unless you have a 3 way fridge.
So battery cannot be disconnected while using propane feature.
Old 06-07-2012, 10:00 AM   #16
I tried this and my refrigerator light stayed on, however I'm not sure it was enough juice to actually keep anything cold or run the pump/motor or whatever powers the actual cooling process. So I don't think it will run the refrigerator, just enough to keep the light on and provide false hope that it's cooling.
2013 Mini Lite 2109s
2006 F150 STX 4x4
Smitty75 is offline   Reply With Quote
Old 06-07-2012, 10:21 AM   #17
TURBS's Avatar
Mine keeps just as cool on propane as it does on shore power.
Low battery voltage would affect the operation of running on propane.
Your tv should ..... if hooked up and working properly should charge battery while running down the road.
If not hooked to shore power and not hooked to tv running your fridge on propane with discharge battery.
Also keep in mind 24 hours cool down time is minimum on fridge before use.
And also don't stuff it full of warm beverages that will take all your cooling away.
Old 06-07-2012, 11:35 AM   #18
RV fridges actually run better on propane than electric.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 06-07-2012, 12:34 PM   #19
TURBS's Avatar
Id second that.
Also double check that the temp probe is in the highest point within the slider
battery, battery disconnect
