Old 05-26-2019, 09:06 AM   #1
Help! Door wont open!
Hello
We just picked up our brand new geo pro 16BH on Friday. We locked the doors overnight, and when I went to go in this morning, I unlocked both locks, and could pull the handle, but the door won't open. Any ideas on what I can do to get into our trailer?
Thank you
Su
curlysu80 is offline   Reply With Quote
Old 05-26-2019, 09:40 AM   #2
Iwannacamp's Avatar
Not familiar with your unit.
Mine hangs sometimes because of the stupid screen door. It will open if I pull on it.
Did you try and relock and try again? Push in on door and try? Pry gently on top or bottom of door up/down just a bit. Is it fairly level?
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 05-26-2019, 10:10 AM   #3
Oaklevel's Avatar
Is the trailer sitting fairly level?? Are you positive both locks are unlocked . I've done similar things.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 05-26-2019, 10:22 AM   #4
Once had a door problem when I raised the stabilizers too high. Try releasing some upwards pressure on them. Just a thought.
Daves rv is online now   Reply With Quote
Old 05-26-2019, 10:42 AM   #5
Had to do this for my brother-in-law last year. Is there access from storage compartment under a bed that lifts up ? Sorry...don't know layout of those Trailers. I crawled into his compartment pushed bed up, crawled inside and opened door for him.
TheWolfPaq82 is offline   Reply With Quote
Old 05-26-2019, 12:21 PM   #6
Airdezaster
This has happened to us on our 2509S a few times. You can try pushing in on the door, unlocking both locks, then pushing in on the door again (at handle), then pulling the handle and tugging briskly (not forcing mind you) on the door outward. Hopefully that will work for you.
adezafra is offline   Reply With Quote
Old 05-26-2019, 12:42 PM   #7
Just had new door installer and it sticks at times. I grab it at the door handle and at the bottom of the door there is a lip that I can pull on, opens every time.....Good Luck.....
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD SLT short bed w/gravity flow Fuel Tank
Firestone Airbag Ride Rite system
paverdave is offline   Reply With Quote
Old 05-26-2019, 12:42 PM   #8
Make sure you're actually unlocking the door. On my Mini Lite, the dead bolt unlocks by rotating the key one way and the handle unlocks by rotating the key the other way.
Dealer also told me to always return the dead bolt key to the center position after unlocking the dead bolt. I don't really know if it's necessary, but I've always done it and have had no issues.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 05-26-2019, 12:44 PM   #9
Wolverine 1945's Avatar
You might consider yourself Lucky,,,
Some folks get locked inside !!!
Locks like most all parts in our RVs come straight from China !!!
If you are lucky enough to get them unlocked,,, Lube them with Dry Lube,,
Often !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-26-2019, 12:53 PM   #10
We had the same thing happen - twice. The first time we were inside the camper & DH had to use a table knife as a screwdriver to take off the door handle. (Lesson learned there - tools are now reachable from INSIDE!) Once he put it back together, all worked well ... until it didn't. That time we were locked out so I crawled inside thru a compartment with a screwdriver, removed the door handle & got it open. That's when we ordered a new lock!
2016 Rockwood 2504S
Doxies in the Rockies is offline   Reply With Quote
door
