Old 03-02-2014, 11:37 AM   #1
MommaHuffman's Avatar
Help finding hotwater bypass valve!
I have an 07 Roo 233. When I open the access door for my hot water heater, it shows how to turn it on. That's all fine, but how do I find my bypass valve??
2007 Rockwood Roo 233
2006 F150 XLT Crew Cab
MommaHuffman is offline   Reply With Quote
Old 03-02-2014, 11:47 AM   #2
jonrjen's Avatar
I'm not familiar with the Roo, I hope someone will come along soon to help you out. You may try a search on YouTube, it's amazing what can be found over there.
From my past experiances and numerous RVs owned, I have found:
Many times the hot water bypass valve will be located behind the water heater. And sometimes it maybe located no where near the water heater.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 03-02-2014, 11:57 AM   #3
TURBS's Avatar
Its most likely behind the water heater normally accessible from the inside of of the camper via a false panel or door.
May or may not look similar to this picture.
Ps this pic shows the bypass in operation mode.
TURBS
Think spring!
The last man standing also has a sharpie
Old 03-02-2014, 12:08 PM   #4
I went to You-Tube as you requested and found some important information! Thank you!
Old 03-02-2014, 12:11 PM   #5
TURBS
Think spring!
Yes! It was located under the seat of the dinette! There are red hoses and blue hoses like in the picture with two different valves. Assuming my unit was winterized before I purchased it, the important bypass valve should be the one that's turn on! Thanks for your help!!
Old 03-02-2014, 12:22 PM   #6
Brother Les's Avatar
The picture shows three valves... one on the red...one on the blue.... and one in-between. The one in-between is the 'by pass'. Do you have three valves behind the WH?
Brother Les
bypass, water
