Old 08-19-2016, 10:01 PM   #1
help frig problem
2017 rockwood ultra light. Have a Dometic dmr/doc series 7 frig. It has selection for lp or auto which uses Elric or propane. Has 3 blue lights. That let you select low med high for temp. They also serve as fault lights. Just arrived Friday night. Seaside OR. Have 2 lights flashing. Which says he problem with the thermostat Needs service. There is no help around and it is weekend. Cannot find reset outside on back of frig. Trying to search on Internet. No answers yet. If anyone has suggestions. Send them over. Thanks
Jim and Silene
2017 Rockwood 2906WS
2014 Dodge Ram 1500 Hemi 5.7
Firestone Airlift 1000, Equalizer Hitch
Augustpilot is offline   Reply With Quote
Old 08-19-2016, 10:16 PM   #2
I may not be much help but you might try turning everything off wait a minute or so then turn it back on. Wish I could be more help. Good luck!
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 08-19-2016, 10:30 PM   #3
jbhodj's Avatar
While I don't have your exact model i had many issues with a Dometic fridge. It would run on propane but not electric. So I suggest switching over to propane first. Make sure you bleed the air thru stove before switching. If it runs on propane and not electric then the problem cud be anything but first place to look is outside under the vent cover there shud be a black cover that you can remove. Under that is a circuit board and a small 120v 5 amp fuse. This maybe blown and needs replaced. Also on the flu there could be a thermal coupler with a tiny little reset button in middle of that that has popped. Pressing that little reset button if protruded will reset it. If it does it again then you have a bad thermal coupler and you have to unplug it and jump the wires plugged into it with an ATC spade fuse. This is temporary fix only to get you by.
jbhodj is offline   Reply With Quote
Old 08-19-2016, 10:35 PM   #4
jbhodj's Avatar
Continued. If it runs on propane and not electric then I'm afraid you may have a bad unit or element that heats up the anhydrous to start the cooling. If you can get it to run on propane let it crank on that for awhile and then after its cooled down some switch over to electric. I was told that just starting out on electric some Dometic unit elements heat up to fast blowing that little fuse and shutting down.
Again try propane only first and see what happens. If you have a tester make sure you have power on receptacle under vent cover. Look for that little fuse and check it.
Old 08-21-2016, 07:32 AM   #5
Head Rambler
If you haven't already gotten it figured out. That error message is actually the overheat thermostat (hi temp cutout).
If you look at the manual you'll see what's called a thermofuse in the drawings. This is the device they're calling the Overheat Thermostat. If you know how to use a multimeter, turn off all power (12 & 120 volts), unplug one of the wires and test the resistance across the device. It normally reads zero ohms. It's most likely open (∞ infinite). It could be that the burner/element has overheated the flue, or it could be that the cutout failed prematurely.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-21-2016, 08:10 AM   #6
raytwntrvlr's Avatar
Hmmmmm...
As the owner of a "blue light special", I read this post yesterday and saw more replies. Some not very helpful!!
Glad someone came along who knows what is happening. A real bummer to have troubles with the refrigerator.
Hope you can get things working.
Happy Camping
2015 Flagstaff Super V 26VFKSS Emerald
2013 RAM 2500 CC 4X4 6.7 CTD
Sold... 2013 Shadow Cruiser 260BH
raytwntrvlr is offline   Reply With Quote
Old 08-21-2016, 02:15 PM   #7
You Were correct
Checked the ohm reading across the thermofuse, have a reading showing switch closed, the back button appears to be all the way out, cannot push back in. Maybe the thermofuse is good for one time. When get this fixed, maybe need to install extra fans in back of frig as others have done for extra cooling
Jim and Silene
Old 08-21-2016, 03:04 PM   #8
Head Rambler
If it's reading zero ohms (or very close) then it's good and there's another problem. Most likely with control board or display.
If it's good, you can try removing all power for 30 minutes and seeing if it resets the lights.
Gotta go campin!
Old 08-22-2016, 07:58 AM   #9
If problems continue after you get fixed as I to had the double flashing blue lights they replaced a few parts that would normally cause this problem and yet I still had the same issue after a week, found out we were getting low voltage from the converter. They replaced the converter and we have not had a problem afterwards
Good luck
Camperstewart is offline   Reply With Quote
Old 08-22-2016, 01:03 PM   #10
Head Rambler
Good info Stewart. I didn't think about low voltage on the DC side.
Gotta go campin!
light
