Old 06-14-2018, 09:31 PM   #1
Help....how to get cable TV?
We have a 2017 mini Rockport. Today we pulled into a park with cable. But we can't figure it out.
We get about 10 channels OTA.
We have a coax running from park box to outside cable jack.
We have tried turning the booster off and on, scanned too many times to count. Tried putting a coax from wall plate to TV
We even tried running cable from satellite ports , well, why not right?
Nothing... All we get us over the air stuff.
Any other suggestions ?
danilyn22 is offline   Reply With Quote
Old 06-14-2018, 11:39 PM   #2
bikendan's Avatar
Did you change the tv settings, from ota to cable, turn the booster button off and then scan?
Equalizer WDH
Old 06-15-2018, 06:25 AM   #3
Yes. We did all that, several times in fact!
Old 06-15-2018, 07:16 AM   #4
If you have a long enough cable wire try running it to another site's connection
you may have a bad cable connection at your site
bkool2323 is offline   Reply With Quote
Old 06-15-2018, 07:40 AM   #5
Mr. Dan's Avatar
X2 or the entire park system may no be ON.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 40; booked = 0
Old 06-15-2018, 07:43 AM   #6
rsdata's Avatar
often heard that cables internal to your trailer are not connected when they pass thru the walls when it was built...
bring cable into a window or door and hook direct to TV to test that...
INPUT antenna cable USING screen menu then scan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
rsdata is online now   Reply With Quote
Old 06-15-2018, 07:55 AM   #7
western NC mountains!
formerFR's Avatar
yes, try to run the coax cable into the coach and directly to the tv
change the tv input to CABLE, or similar setting... it may actually be 'TV' setting
scan for channels
if nothing, then it's the park's issue, and they may actually require you to have one of their 'cable boxes' in order to use their system. Ask if needed. Otherwise, it could also be that your TV can not 'unscramble' the digit Cable channels. Maybe : /
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
90,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is offline   Reply With Quote
Old 06-15-2018, 10:35 AM   #8
We got it. The TV had to be on channel 3! I had a feeling it had to be set on a certain channel but nothing I read said what channel! Lol. We don't do cable at home so this wasn't intuitive to us!
Thanks for all your help!
Old 06-15-2018, 10:58 AM   #9
Oaklevel's Avatar
Probably was in your TVs manual.
...... Glad that you found it. I was going to ask who the cable provider was as we have found out Spectrum cable only certain brands of TVs will work on their system without a box.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 06-15-2018, 02:07 PM   #10
Evereddie's Avatar
Oh, you must have a cable box that selects the channels. Think you forgot to mention that. Glad it's working now.
Rockport makes good shoes but.....
Evereddie is offline   Reply With Quote
cable
