Old 08-24-2016, 11:16 AM   #1
Help! Stabilizing Jacks
I have a 15 month old Rockwood 8327ss with Lippert electric stabilizing jacks! My front one will NOT extend. It makes the noise and then cuts off. Nothing? I am on shore power and the back unit works well. I have checked fuses? Any ideas??? Thanks
fkwalter is offline   Reply With Quote
Old 08-24-2016, 11:21 AM   #2
Is it possible you are at the limit?
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 08-24-2016, 11:25 AM   #3
It is stuck in the up position. Limit?
Old 08-24-2016, 11:25 AM   #4
fonzie's Avatar
Probably stuck, use crow bar to free up and then operate as usual.....hope this is it.
Fonzie
Old 08-24-2016, 11:28 AM   #5
Thanks, but I tried the crow bar trick! Nothing???????
Old 08-24-2016, 11:47 AM   #6
CampingGator's Avatar
We have a Salem Hemisphere and have had the front and the back stabilizer control (or whatever it is called) go out. They needed replaced (two different times). Our unit is just over one year old. The first went out after we had it a few months and the second went out this summer. Our RV repair just orders a new one and then installs it. Do you happen to have the Android tablet in your RV? If so, the stabilizers will work off of that, even if the manual outside control is not working. That being said, this summer our tablet went out at the same time, so the stabilizers did not work at all until we had the tablet and the control replaced.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is offline   Reply With Quote
Old 08-24-2016, 11:57 AM   #7
fonzie's Avatar
Try your manual handle to bring them down......
Fonzie
Old 08-24-2016, 12:12 PM   #8
The manual handle will not work unless you unhook power from the motor!! Plan to take unit to a local repairman tomorrow! Most dealers are VERY slow on any repairs!!
Old 08-24-2016, 02:23 PM   #9
Got it done!! My neighbor came over and he turned the manual crank down HARD as I pushed the extend button. Apparently stuck in place! My problem was retracting the jacks TOO long and it stuck the stabilizers. Most know this but NEVER hold the switches too long!!! Bring them up gradually the last several inches! Thanks for every ones help!!
Old 08-24-2016, 02:42 PM   #10
Ford Idaho's Avatar
Good to have a neighbor who is willing to help out!
And thank you for posting the fix, it may help someone with a similar issue.
Old 08-25-2016, 10:18 AM   #11
AKA: 'tiredTeacher
awellis3's Avatar
Watch as the last jack in the pair being raised nears the top bracket. NEVER let the axle at the point where the brace joins the main leg to contact the upper bracket. That's when the jam occurs.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
jacks
