Old 12-02-2015, 07:33 AM   #11
No, there is a curtain. If I had doors I am sure that would solve the problem.
Tracyt is offline   Reply With Quote
Old 12-02-2015, 07:36 AM   #12
I have a 2016, however it has a curtain and not doors. I have looked at some other models that have a little bit larger shower and those all have doors but my model doesn't?
Old 12-02-2015, 07:37 AM   #13
I may have to try that.
Old 12-02-2015, 07:44 AM   #14
Because the model year change over is anything but consistent. You have a 2016 per the yellow sticker/ VIN number but it was probably built while they were trying to use up the supply of the old style neo angle shower bases they still had. Its not unlike the Roo's for 2016. Supposedly the 23WS replaces the 23SS and on the website and new 2016 brochure the 23SS is no longer shown, yet you can do a web search and find some 2016 model year 23SS units.
Hence the disclaimers that always say they reserve the right to change specs without notice.
Having had two other brand hybrids with the same size shower as your 2104, it takes practice to shower in one of those without having the flood.
Mr Havercamp is offline   Reply With Quote
Old 12-02-2015, 07:53 AM   #15
Yes, thank you. I may have to try some of the suggestions like splash guards and velcro. I appreciate everyone's input. Thank you!
Old 12-02-2015, 11:32 AM   #16
I'm not sure if it's applicable to your shower design, but I installed splash guards in my shower. Greatly reduced the amount of water in the floor when taking a shower.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
ebcobra93 is offline   Reply With Quote
Old 12-02-2015, 11:37 AM   #17
I have a Rockwood Mini Lite 2104s, when taking a shower I end up with a flood in my camper. It's not a plumbing issue, I believe the shower pan is just too low or shallow-a poor design. Does anyone have a fix? We love everything else this is the only issue we have.
Thanks,
Tracy
If it has a door check the bottom seal a strip of rubber in a narrow groove.
Myrle is offline   Reply With Quote
Old 12-02-2015, 12:06 PM   #18
Once you have ruled out a leak underneath the shower pan, it is probably a leaky glass panel seal or the gasket underneath the door. You can investigate this by running the shower head directly against each shower glass panel and the shower door and have someone see if that is the leak source.
If the shower glass panels are leaking near their frame, it means you need to remove the glass panel seal bead and redo the seals. If the gasket on the door is torn or deformed, it may need to be replaced.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is online now   Reply With Quote
Old 12-02-2015, 12:11 PM   #19
Who Dares, Wins
doc73's Avatar
I added command hooks to hook the curtain in a bit on the ends. We would have water push around the curtain from splashing. I also cut the curtain to not lay on the floor. When it did it tended to bunch on the shower / tub edges and allow the water to leach through.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 12-02-2015, 12:46 PM   #20
Thanks,
Tracy
I have a 2014 hemisphere fw and i had the same problem ,take a gander at the bottom of the door and see if there is a gap in the rubber seal and also see if they caulked the seal around the door properly...i had to recaulk mine..what i did was i got inside the shower and poured water on the bottom of the door.....good luck
Save a beer for me!!! Happy Trails....Be Safe....
sunnyinfla is offline   Reply With Quote
water, show, shower
