Old 07-03-2019, 06:34 PM   #1
Hey Murphy, Give me a break!
These curved wedges, available in both poly and metal, are popular and effective as either jacks or leveling devices. Usually carried to be a jack, my use yesterday was to up-level one side just a few inches...but my spotter got distracted by a visiting dog for just a few seconds...so when I got my "STOP" yell, it was just too late. This is a picture of what I saw, in a zero cell signal environment, and that thing was wedged in TIGHT between the tires. So what to do?
I can't drive either forward or backwards because each tire is imparting a different directional force making matters worse.
Macgyver move #1, which was to release the air out of both tires, didn't budge the thing.
MacG move #2 did the trick...using the tow truck's factory jack, I eventually was able to remove a wheel and get things back under control.
By the way, those anti-sway bars on an Equalizer hitch don't enjoy being jacked around...
Of all the lists I keep, the most important one, the one that curiously isn't written down anywhere, is entitled "things to remember".Click image for larger version
metalsideup is offline   Reply With Quote
Old 07-03-2019, 06:45 PM   #2
If you have a compressor, you might flatten rear tire then punch it out with hammer handle. If not, consider removing front tire. Another possibility would be to pull larger end outward with rope if you can then hammer center portion downward.
hshaynes is offline   Reply With Quote
Old 07-03-2019, 06:53 PM   #3
wmtire's Avatar
OK, that is definitely a new one to me, at least. Will have to remember this, for future.
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
Old 07-03-2019, 07:03 PM   #4
Coach
Glad to hear I'm not the only one that has easily distracted spotters.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-04-2019, 05:58 AM   #5
Wow ! We had the same thing happen just the other day. Mine I stuck horizontally and I couldn't back up or go forward. I was able to pound it loose. Makes a hell of a noise when you try to move the trailer. I did more stupid stuff that weekend than before, not a newbie, but only 3rd time taking out new rig. I like getting stupid stuff out of the way early on.
Jim & Kathy
Bailey, waiting at the Rainbow Bridge
Gracie, a rescued Beagle
2007 Chevy Tahoe
2008 FR Surveyor 233T
JimChow is offline   Reply With Quote
Old 07-04-2019, 06:03 AM   #6
marinerjoe's Avatar
One other option is to use a jack to raise the camper enough to tap the wedge out. Iíve jacked up my camper on the frame in close proximity to the axle with no issues.
Joe
Current: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 07-04-2019, 06:32 AM   #7
Glad I have spread axles on my Freedom Express
2014 Ram 1500 HEMI Lone Star Edition
2018 Coachmen Freedom Express 248RBS
2017 Harley Davidson Road Glide
Roberte52 is offline   Reply With Quote
Old 07-04-2019, 06:59 AM   #8
I think I would've Jacked both wheels off the ground, then rotate left tire clockwise and right tire counter clockwise.
TheWolfPaq82 is offline   Reply With Quote
Old 07-04-2019, 03:08 PM   #9
That's what I would try too. Both wheels should be free to turn either way with no contact with the ground.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 28 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 07-04-2019, 03:24 PM   #10
Iwannacamp's Avatar
Another possible. Block frame on both sides of the wheels as close as possible. Deflate tires and wedge should loosen enough to get out. Re-inflate tires.
2017 Puma 297RLSS
Old 07-04-2019, 03:39 PM   #11
Until your spring hangers break.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 07-04-2019, 03:49 PM   #12
rlh1957's Avatar
NOTE: Cell phones for spotter to driver? Use two-way radios, they always have signal. They are cheap. If that is all you ever use them for, cheap as $15 on the toy aisle at Walmart.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 07-04-2019, 04:20 PM   #13
This is a perfect example why I use those cheap 1x8 and 2x8 pressure treated boards cut to length to fit under my tires. Do not need a spotter to drive onto and no one is looking to make a five finger discount buy on them.
Walholler is offline   Reply With Quote
Old 07-04-2019, 08:13 PM   #14
I found that the $60 I spent on that type of leveler was a complete waste of money...It slides in gravel...not cool...
RookieRV is offline   Reply With Quote
Old 07-04-2019, 08:21 PM   #15
madatme's Avatar
I used my camco wedge yesterday in gravel and it worked fine
2019 FR Vibe 28RL
2018 Silverado 1500, Husky Centerline TS
3 Great Danes, 1 Weimaraner
Wonderful co-pilot
madatme is offline   Reply With Quote
Old 07-05-2019, 08:23 AM   #16
david_reaves's Avatar
Be careful what you ask for when you ask Murphy for a "break." That may mean a broken AC, Fridge, heater, water line... the possibilities are almost endless!
Taking a wheel off would have probably been my solution, too. Due to recent events, I've become very efficient with tire changes on the camper. Not Indy pit speed, but I get it done.
david_reaves is offline   Reply With Quote
Old 07-05-2019, 09:09 AM   #17
Time to replace the "spotter"
tonys is offline   Reply With Quote
Old 07-05-2019, 09:32 AM   #18
Iwannacamp's Avatar
Mmmm. Prolly easier to ask for neighborly assistance. Replaced a couple times...it ainít easy. Ok. I got replaced.
2017 Puma 297RLSS
Old 07-05-2019, 11:05 AM   #19
That sounds like it would work!
Bytesponge is offline   Reply With Quote
Old 07-05-2019, 06:36 PM   #20
D W
D W's Avatar
I have seen this before (two times in-person). Those things get wedged in between the tires like totally expanded X-Chocks. You can't move anything. One guy had to let all the air out of both tires, remove lug nuts, then force the wheels off. The other guy whipped out a saws-all and made quick work of the wedge.
I wouldn't own a set of them.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
