Old 03-15-2016, 08:25 PM   #1
Pyromedic's Avatar
Hit the Scales
We went and picked up the new Wind Jammer today and stopped at a CAT Scale on the way there with just the truck and on the way home with everything. Here's what we found out. So much for the 850lb tongue weight. The rear axle of my truck went from 2720 to 3680 with the TT on it. These numbers are with the camper just picking it up at the dealer so, there is a battery and 2-30# LPG tanks. Other than that we have no personal gear inside. Take a look at the Scale sheets for yourself.
2005 Nissan Titan crew cab
2017 Rockwood Wind Jammer 3006wk
Truck only
Name:	ImageUploadedByForest River Forums1458091482.568022.jpg
Truck and Trailer
Name:	ImageUploadedByForest River Forums1458091499.238767.jpg
Pyromedic is offline   Reply With Quote
Old 03-15-2016, 08:29 PM   #2
Crusadernoob's Avatar
Looks pretty close to me considering you got propane.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 03-15-2016, 08:41 PM   #3
Platokidd's Avatar
Truck only
Attachment 102037
Truck and Trailer
Attachment 102038
Is that with or without a WDH ?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-15-2016, 08:52 PM   #4
Fulltime family RVer
So, 850 lbs of advertised weight plus 60 pounds for propane = 910. And add your battery and you're hitting the 950 pounds that you're scaling out with.
What's the problem?
ependydad is online now   Reply With Quote
Old 03-16-2016, 04:33 PM   #5
Pyromedic's Avatar
I do have a WDH. I'm just saying I'm glad I went with the 12k equalizer instead of the 10k that the dealer wanted to give me.
Old 03-16-2016, 10:17 PM   #6
Hit the Scales
Some of your tongue is being transferred to the trailer axles so it is really heavier than the 900 lbs added to the rear axle. Probably another 150 lbs or so. The good thing is that the hitch was set up really good to restore all of the lost front axle weight except 60 lbs.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-16-2016, 10:43 PM   #7
Did you know it was "Back There"? Youroo!!
Old 03-16-2016, 10:45 PM   #8
Trouble maker..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 03-16-2016, 10:52 PM   #9
Done with this
I trust the Titan has the tow package? Have you replaced or checked the rear shackles on the truck? They have been known to fail and send the rear springs through the bed.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 03-19-2016, 10:04 PM   #10
Pyromedic's Avatar
Hit the Scales
Yes I have a full tow package on it. I also have Firestone Airbags installed on the rear. I wasn't aware of rear shackles failing.
scales
