Old 06-09-2011, 03:08 PM   #11
Hoo Dad's Avatar
Originally Posted by 4Rasnicks View Post
This is very interesting for me. I have had a similar issue with mine. Everytime I open the door to the tank I smell propane. Not too much, just a little. I have checked hoses, regulators, et. Its 2011 8281SS. How did you check the tank? Soapy water? Where was the leak at? Thanks.
I actually got lucky that I found it. I unhooked the tank and set it on the ground. I applied so much soapy water to the valve stem it flowed across the top of the tank and it was then that I noticed a very small pin hole in the top of the tank approximately 1/2" out from the weld where the valve is threaded into the tank.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
