Old 12-28-2015, 10:58 PM   #1
Hook new TV to Genesis
I have a 2013 Rockwood 8325 TT. The TV slides down into the entertainment center but I have replaced it with a larger TV that just sits on the counter. I did this a while ago and didn't try a DVD so I must have missed something when I put the new one in. Does anyone know how to hook the Genesis to the new TV?
2013 Rockwood 8325SS - 35 feet
2007 GMC 2500HD Diesel
Buster & FlipperDoodle (cats & copilots)
Full-timer since 2012
GVJeeper is offline   Reply With Quote
Old 12-29-2015, 12:34 AM   #2
The Genesis has a HDMI output on its backside and your new TV should also have a HDMI input. You may have to remove the Genesis from the wall to access the HDMI output if you did not already have the HDMI cable connected to your old TV.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 12-29-2015, 01:27 AM   #3
I'll check on that but I don't seem to remember an HDMI cable end hanging around in the cabinet where the old TV dropped down. BUT I'll take another look....have to take the fireplace out to get there so will check on it tomorrow. Thanks!!
Old 12-29-2015, 04:02 AM   #4
Witch Doctor's Avatar
More then likely your Rockwood did not come with a HDMI cable I know mine didn't. Mine came with only RCA jacks, make sure your Yellow jack is plugged in both the TV and the yellow wire in the back of the Genesis. If your going to use HDMI there is a plug in on the back of the unit, you will need to pull the unit out. I have the Genesis 3.0.. PS: There is also a fiber optic line plug in also, some of the new TV's do not come with jack outlets anymore....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 12-29-2015, 06:29 AM   #5
The only Fiber optic on some of the Newer TV's is for the Sound Bar? Youroo!!
youroo is online now   Reply With Quote
Old 12-29-2015, 11:24 AM   #6
Well that could be true, but my statement was that the Genesis 3, also has an optical connection in the back. I have one and installed that an a HDMI cable. I have good surround sound, and great DVD not blue ray. But I have not bought a new CD in years. Aren't you supposed to be hunting or repairing that snowmobile?.....
Old 12-29-2015, 04:10 PM   #7
Hook new tv to Genesis
We have a 2013 Rockwood 2608ws and ours has the cable -cable and a yellow rca cable that's all you need for your DVD/'s a to work.I bet the yellow cable fell behind fireplace when you removed old tv. Those are the only 2 cables besides power cable.
Joe-Barb is offline   Reply With Quote
Old 12-29-2015, 08:22 PM   #8
I FOUND IT!!!! I had to remove the fireplace and hunt through a ton of wires and cable to finally come across an HDMI cable not hooked to anything. Hooked it to the TV and it worked.
Old 12-29-2015, 11:05 PM   #9
What do you mean by a Ton of Wires! Youroo!!
Old 12-30-2015, 03:21 AM   #10
Glad you found it in that rats nest they leave when they install stuff. A 10 year old can due better then the picture above. The picture looks just like mine, My antenna was un-hooked took awhile to find it in that mess above.
