Old 06-28-2015, 01:13 PM   #11
Does it only do this when you are running off electric? Mine did this twice when I was using electric only and, when it was working correctly, I would get temperature variances of almost 10 degrees on hot days. I switched over to gas and the freezer doesn't get warmer than 5 degrees and the fridge gets no warmer than 37 even if it is 98 outside.
Middleburg Redneck is offline   Reply With Quote
Old 06-28-2015, 01:34 PM   #12
Not the freezer!!! OK!!......Is the clip with a wire attached connected to the "vane" at the back of the lower compartment????
Jim in Halifax is offline   Reply With Quote
Old 06-28-2015, 01:51 PM   #13
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
You're at a higher elevation......if you're using gas instead of electric....that's probably your problem. The elevation is causing your problem.
Grampa Jim is offline   Reply With Quote
Old 05-08-2016, 06:20 PM   #14
Dometic refrig. Junk?
From day one, five years ago, the refrigerator worked on and off. On electricity,or gas ,it would run for a month or sometimes a day. then cut out. I turn it on and off and it runs again. maybe 2 or 3 months, sometimes a day.
Anyone had the same problem?
Ps.Seems like it should switch to propane and cool if problem with elec.
The Danish Guy is offline   Reply With Quote
dometic, refrigerator
