Old 06-27-2015, 07:52 PM   #1
Hot and cold Dometic refrigerator.
Help. My 2010 Dometic refrigerator is acting up. It will work for weeks and then the temp. will suddenly go up to 60deg. It seems like when I then cut the power and turn it on after a little while the temp. will drop down to 38deg. That can go on for a good while and then it will stay cold for weeks again before it acts up again. The freezer stays frozen all along. Any help will be appreciated.
The Danish Guy is offline   Reply With Quote
Old 06-27-2015, 09:19 PM   #2
Klbrown53's Avatar
Check the light. We were having trouble with ours not getting cold and I discovered that the bulb was staying on. How did I discover that? I touched the bulb when I opened the door and burned my finger. I do not know why they use such a high heat output bulb........
Short term solution, removed the bulb.
Klbrown53 is offline   Reply With Quote
Old 06-27-2015, 10:11 PM   #3
Thank you. Tried that. Not the case.
Old 06-28-2015, 07:20 AM   #4
Georgia Frog Rally 2017
aceinspp's Avatar
Does your refrig have the built in fan. If so maybe not working right or the refig is getting to cold and freezing up. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2015--46
Days booked for 2016--60
Days camped in 2016 so far 51
Old 06-28-2015, 07:53 AM   #5
Was the door open just alittle? that will do it and leave the freezer cold
Big Bill is offline   Reply With Quote
Old 06-28-2015, 08:28 AM   #6
Herk7769's Avatar
Low ammonia levels will do this.
Remove the outer cover and check for a leak. Look for greenish yellow stain.
Old 06-28-2015, 10:40 AM   #7
I will check for leak. I guess it could be that it freezes up. I am camped at 10000 feet and it gets cold at night. In the day time the temps. are around 65deg. but often down to freezing at night.
Old 06-28-2015, 10:53 AM   #8
mud yapster's Avatar
My fridge did the same thing and I found my light bulb staying on inside my fridge. I removed my light bulb and though it in the trash. My fridge now stays at 34.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 06-28-2015, 12:16 PM   #9
Is yours a four door model? We had a similar problem and it turned out that the vertical bar between the two doors wasn't flipping completely, leaving a gap through which cold air flowed. Wait 'til dark, put a lighted flashlight in the refrigerator, and turn out the lights in the room. If you can see light around the refrigerator .....
helferdm is offline   Reply With Quote
Old 06-28-2015, 12:22 PM   #10
Have you made sure the fridge is completely level? These units require that it is level.
I would also check to see if the vent on the roof is clear and free of obstructions. The vent must have air flow over the external coils. Heat build up in the outside part of the fridge will kill the cooling effect.
And, I would also look for an ammonia leak. Yellow stains....
MOODMAN is offline   Reply With Quote
dometic, refrigerator
