Old 06-16-2019, 07:37 PM   #1
S Spackler's Avatar
Hot water feeds toilet?
I have a 2018 2706ws. Noticed on this last trip that the toilet had no water pressure and the the rest of the trailer had normal pressure. I was dry camping so I turned the pump off and released the pressure on the cold water side so I could pull the toilet water valve out to see if that was the problem. Well when I pulled the feed line off HOT!! water came pouring out, luckily there is enough slack in the line to have it drain into the shower. So what I found out is there was debri in the valve from what looked like the anode rod I just changed in the hot water tank. Traced the line back from the toilet and found my toilet is plumbed on the hot water side of the feed. Question is is this normal for better cleaning? And if it is not normal should I change it? Also if it is normal how do I keep anode rod material from plugging up the toilet spray port? Any info/ advice would be appreciated.
S Spackler is offline   Reply With Quote
Old 06-16-2019, 07:42 PM   #2
fonzie's Avatar
Not normal. Toilet needs to be hooked up to cold water line.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-16-2019, 07:58 PM   #3
S Spackler's Avatar
Alright thanks that’s what I figured, it’s has not been a problem for the last two years, but then again I don’t touch the water that comes into the toilet�� to check if it’s hot or cold, guess I’ll see if I can cap this line and tee off the bathroom sink.
Old 06-16-2019, 10:16 PM   #4
Did you close the hot and cold (especially the cold) WH valves before you drained your plumbing system last year? If you didn't, you probably pulled crap from the WH backwards into the cold water line, and now it's in your toilet line.
Not sure what you mean by "released the pressure on the cold water side, but that could also easily allow hot water to flow backwards into the cold water line, and hence the toilet line, if you didn't close the cold water valve first. Especially if the toilet line comes off the cold water line very close to the WH.
There is an air bubble at the top of the WH and if the WH was under pressure, then this air is under pressure and could easily push quite a bit of hot water backwards into the cold line as it expands when you depressurize the system.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-17-2019, 09:03 AM   #5
S Spackler's Avatar
When I released the pressure I shut the pump off and turned on the bathroom faucet until no water came out to release the pressure but i opened just the cold side, this is the second trip in a month but the last trip I didnít change the anode rod yet. I know itís not backfeed because i pulled the feed line off after I let the hot water heater fill up again and come back up to temp and I did not drain the cold side and it was still hot water going into the toilet. Iím positive itís a hot water line just wanting to know if someone is willing to touch the water that feeds their toilet to see if it hot or not( haha).
Old 06-17-2019, 09:13 AM   #6
I'd have no qualms about a hot water flush.
aeblank is offline   Reply With Quote
Old 06-17-2019, 09:20 AM   #7
Originally Posted by S Spackler View Post
When I released the pressure I shut the pump off and turned on the bathroom faucet until no water came out to release the pressure but i opened just the cold side, this is the second trip in a month but the last trip I didn’t change the anode rod yet. I know it’s not backfeed because i pulled the feed line off after I let the hot water heater fill up again and come back up to temp and I did not drain the cold side and it was still hot water going into the toilet. I’m positive it’s a hot water line just wanting to know if someone is willing to touch the water that feeds their toilet to see if it hot or not( haha).
It's certainly possible your toilet is hooked to the hot water line, but I'd be very surprised. I don't recall anyone ever reporting that issue. Have you actually followed the line hand-over-hand and verified it ties into the hot water line?
I'm not sure what you mean by "pulled the feed line off." If you mean you disconnected the cold water inlet line to the WH BEFORE you depressurized, I'd agree with you. But you couldn't have done this unless you'd closed the cold water valve first or the WH would have leaked out of the cold inlet. And even if you had closed the cold water valve, you'd still have had water all over the place because pulling off the line would have depressurized the cold side of the system by leaking out of the line.
And If you mean you disconnected your city water, that wouldn't change anything, either. Your city water connection has a built-in check valve that keeps pressure in the system when you disconnect the city water line.
Note also that unless you have a hot water check valve instead of a manual hot water valve (see options 4a, 4b, and 5 on pg 2 of attached diagram), depressurizing the cold side will also depressurize the hot side AND water will flow backward from the WH to the cold line.
And it's not changing the anode that gets the crap in the WH tank. It occurs naturally during operation (where do you think all that "missing anode" stuff goes?), so you've probably got 2 years of calcium carbonate "crap" laying in the bottom of your WH.
Old 06-17-2019, 09:40 AM   #8
Same thing happen to my toilet at home many years ago. It was the diverter valve in the Shower that was causing hot water to flow into the cold water line and then to the toilet when I flushed.
TheWolfPaq82 is offline   Reply With Quote
Old 06-17-2019, 09:47 AM   #9
Yes, that's another possibility.
Check that both the outside and inside shower faucets are fully closed. If they aren't, but that little button that shuts off the shower head is closed, then you've tied the cold side to the hot side. But I'd be surprised on this, too, unless he had been running water to the toilet for some time (a minute or more).
Old 06-17-2019, 11:45 AM   #10
S Spackler's Avatar
Yeah I traced it back and it’s tied into the hot water side on the bathroom faucet I can pull the toilet line and hold the hot water line under the bathroom sink, and when I say “feed line” I’m referring to the line that is threaded into the back of the toilet on the toilet water Valve. I was not hooked up to city water because I was dry camping.
hot water, water
