Old 07-13-2010, 11:39 AM   #1
Nights Camped in 2010 - 2
Hot Water Heater Fill
All,
Quick question about filling the HWH. Do I open the by pass valve until the HWH is full and purged of air then close it? If I understand the system correctly, by pass is used to route water around the HWH for winterizing and would be shut during normal operations. Why open when filling? Thanks,
George Kelly
2011 Rockwood Ultra Light 2604
Dodge RAM 1500 Larime 4x4, 5.7 HEMI
Nights Camped 2010 = 18
Nights Camped 2011 = 15
sailingsuppo46 is offline   Reply With Quote
Old 07-13-2010, 11:44 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Originally Posted by sailingsuppo46 View Post
All,
I keep the water heater by-pass closed. I just open the pressure relief valve. It allows the air to escape. I keep it open until water starts coming out. Just did it Monday evening after I rinsed my water heater out and cleaned the crud off of the anode rod.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-13-2010, 12:10 PM   #3
I think I like your way better. I will forget about the by pass valve and spend to much of my time trying to figure out I forgot to close it. I prefer the kiss method when it comes to these things. Thanks,
George Kelly
Old 07-13-2010, 01:00 PM   #4
milzat's Avatar
George,
After connecting to city water, I open a faucet to purge the air out of the Cold Water Heater.
milzat is offline   Reply With Quote
Old 07-13-2010, 02:53 PM   #5
Originally Posted by milzat View Post
George,
And I thought I was the only one picky about this sort of thing!
For those that haven't figured it out, it is not a HOT WATER HEATER. It is a COLD WATER HEATER!!!!!!! If the water was already hot it would not need heating!!
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 07-13-2010, 03:09 PM   #6
milzat's Avatar
windrider,
High 5..
Old 07-13-2010, 03:32 PM   #7
kvtaylor's Avatar
We do the same thing. After hooking up to water, I purge the system by opening a hot water faucet in the coach. I only use the bypass valve(pressure relief) to drain the tank faster when I remove the anode rod draining the tank for storage.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
kvtaylor is offline   Reply With Quote
Old 07-14-2010, 12:51 PM   #8
I see you don't live in Arizona in the summer. We have hot water coming out of the cold water faucet now. When it comes out cool we know it is winter time.
Old 07-14-2010, 01:59 PM   #9
Ditto here... turn on the hot water faucet and watch it until a steady stream appears. Then I know my water heater is full. Then I turn it on if I need it.
Nights camped in 2010 = 21 nights
2008 Chevy CCab 5.3L 4WD Z71
2008 FR Surveyor 291
Champion Genset
Slpybear, Mrs Slpybear, Three Cubs
slpybeartx is offline   Reply With Quote
Old 07-14-2010, 09:32 PM   #10
Used the facuet method this afternoon and it worked just fine. I got cold water heated by a flame..... Will try the 110 VAC method tomorrow to make sure it works. Later,
George Kelly
rockwood
