Old 04-18-2016, 02:00 PM   #11
bubbles's Avatar
Originally Posted by Lookin2camp View Post
Found a lot of helpful information and tips from you all. I'm having a hard time locating the cold hot and bypass Valves behind the tank. I can feel them just can't see all 3 .It's a small cabinet and space. Any other suggestions with that.? Attachment 105321Attachment 105322Attachment 105323
Rockwood 8312ss diamond package TT
Don't have to see them. As with all standard valves of these types when the valve handle is perpendicular to the tube it is closed. When in line with the tube it is open. This can be verified by feel.
Old 04-18-2016, 06:04 PM   #12
Lookin2camp's Avatar
I gotcha and understand positioning , but still a ridiculous set up , but thanks 🙄
Lookin2camp is offline   Reply With Quote
Old 04-18-2016, 06:36 PM   #13
wmtire's Avatar
I did turn the switch off on the tank outside, as the dealership left in the on position.
Howdy again Lookin2camp, if you look at your switch panel, which I copied the pic of, you have an INSIDE switch for your electric heating element (second switch, top row). The means you have a Suburban SW?DEL model. You can control the electric heating element from this inside switch as long as the outside switch is in the on position. It will not work if you switch the outside secondary switch off, like you just posted you did above.
The Suburban SW?DE models do not have an inside switch like yours does, and the only way to turn the electric heating element on/off is with the outside switch. However you have the SW?DEL model which does have both switches for the electric heating element. Consider yourself lucky, as you have the DEL model and will not have to turn yours on/off outside......as long as you leave the outside switch in the ON position like the dealer had it for you. You can turn your electric heating element on/off with the inside switch on your panel.
In the FAQ link, I originally posted in my first post here, I briefly explain the SW?DEL model you have with your RV's inside switch, with the pertinent part in red below. which I am excerpting below:
Operating on 120 volt electricity
Now for the 120 volt electric option. Some trailers/coaches MAY have another inside switch to turn the electric heating element on, which this element is located inside the water heater. This element works only off of 120 volt AC power, and you must be plugged into some form of 120 volt power for this heating element to work.
Hope this helps, and am so glad you posted that pic of your panel. Since the SWDEL model is becoming more common, I should clarify it more in the FAQ.
Not to get off topic too much, but to help you some more if your RV is set up like many others, do you see that second from right switch on your bottom row called "entry light"? Did you dealer explain that one to you, that if you actually turn that light off at the light fixture itself (if equipped on your RV), then that switch does not do anything. You want to leave your entry light on at the fixture, but turn it off using the panel switch when walking out the door. That way if you come home after dark, you don't have to feel for the light fixture, but just turn it on at the panel with that switch as you step in.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-18-2016, 08:09 PM   #14
Ok cool I was getting to that as well. I turned it off because I am plugged in at home and was afraid of an accidental turn on from inside with no water in the tank by kids or a new camper LOL. I'll remember to switch the on position and leave it there once I de-winterize and fill the tank. But thanks for looking out !
Old 04-18-2016, 08:11 PM   #15
I appreciate your knowledge and getting me setup! Thanks
hot water, tank, water, water tank
