Old 08-14-2015, 11:06 AM   #1
Hot Water Temperature
Is there a way to adjust the temperature? We thought the dealer showed us but can't find it now. Our second trip in mini lite 2502 ks - lots to learn!
the-s-moores is offline   Reply With Quote
Old 08-14-2015, 11:31 AM   #2
Fulltime family RVer
Generally not. One thing you can do is if you have winterization valves- I've found that I can crack open my winterization valve a little to let cold water mix with the hot water and it cools it somewhat by the time it gets to the tap.
Old 08-14-2015, 02:30 PM   #3
bikendan's Avatar
no WH temp adjustment in any FR product that i know of.
some have installed a higher temp part, not sure what it is.
as said above, if you've got temp problems, you should check your bypass valves on the WH.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 08-14-2015, 03:06 PM   #4
Not problems- you can play with the bypass valves to cool down the water before it reaches the sinks intentionally.
Old 08-14-2015, 03:27 PM   #5
We're just the opposite, we wanted the water hotter so I replaced the factory 130 hi limits with 142 hi limits. Uses less hot water.
hot water, water
