Old 08-02-2011, 10:00 AM   #1
Happy Camper
dfrauhiger's Avatar
Hot Water thermostat adjustment
We have a 2012 Roo21ss. I read thru the manuals but can not find if and where the thermostat for the hot water can be adjusted. The water is way too hot to the point it can burn your hand, so we would like to lower the tempature. Thanks
dfrauhiger is offline   Reply With Quote
Old 08-02-2011, 11:33 AM   #2
Triguy's Avatar
IIRC, I have a Suburban in my 233s and I don't recall ever seen an adjustment on mine. I think that most HWH with DSI come with a preset thermostat. Maybe you can retrofit something from suburban.
FWIW, we had a camper in the past with a gas only water heater - no direct spark and no electric element. I needed to light that by going outside and light a pilot. That heater had a dial that I could move between warm and hot.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-02-2011, 12:28 PM   #3
bikendan's Avatar
as far as i know, the temp is not adjustable.
you may want to have it checked out by the dealer.
maybe the water temp sensor is not working right.
Old 08-02-2011, 04:04 PM   #4
Anacortesians
Many w/hs aren't adjustable. The one on our old '85 rig would get hot enough to run a steam engine. The one in our current rig is more reasonable - haven't had to consider adjusting it.
I am surprised to discover there's no temperature adjust on the fridge/freezer.
Frank and Eileen
No longer RVers or FR owners
