Old 06-29-2015, 09:32 PM   #1
House Battery not charging from truck
I just completed a 4000 mile trip with the RV and truck and had 0 problems but my 8327ss battery is running down. I metered the truck out and it is supplying 13.8 volts on the correct pin but the battery is not being charged. If i plug it up the inverter will charge it and it works fine. Is there something I can check inside that will let the truck charge the battery?
firedaniel is offline   Reply With Quote
Old 06-29-2015, 10:01 PM   #2
Dave_Monica's Avatar
Check and find the truck charge line from the 7 pin plug at the connection above the camper's battery. It should be connected to the auto resetting circuit breaker the same terminal as the camper's (+) wire. May be a broken/faulty connector before that also.
Dave
Old 06-29-2015, 10:25 PM   #3
Thanks I guess Ill have to trace it out. The trucks fuse was blown. When I replaced it and checked it its still not charging.
battery, charging, truck
