Old 12-25-2015, 02:12 PM   #1
How can I run an extension cord in without ruining something?
We are parked long term. Have extra plugs outside at park. Would like to run an extension cord in the living room to power a space heater that won't subtract from our thirty amps. Any ideas?
episodic is offline   Reply With Quote
Old 12-25-2015, 02:16 PM   #2
Yes run a Search at the Top,many Post's W/Pic on Install of Rec.through the Side for X-Cord! Youroo!!
Old 12-25-2015, 02:19 PM   #3
yes you can,use one that will handle the amp draw of the heater
Big Bill is offline   Reply With Quote
Old 12-25-2015, 02:20 PM   #4
If you have a slide out on that side, run the cord under the slide and towards the end and push it past the rubber seal if you can.
Pipeman is offline   Reply With Quote
Old 12-26-2015, 07:35 AM   #5
Arn
Arn
X2. You may have to close the slide a couple of inches just to feed the cord through. I actually run an indoor extension cord with a flat plug out and connect an outdoor cord where it comes through the slide. Inside I have a power bar connected so I can run 2 heaters or a 110v cooler.
Arn
Arn is offline   Reply With Quote
Old 12-26-2015, 08:18 AM   #6
Georgia Frog Rally 2018
aceinspp's Avatar
X 3 Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 12-26-2015, 08:29 AM   #7
Running (2) heater's from (1) Ex cord plugged into a (Power Bar) running across a Rockwood slide that is Covered with Carpet sounds like a (FIRE) Trap!! A Cord and Power Bar that would be Heavy enough to power (2) Heaters would be Large and Heavy! Youroo!!
Old 12-26-2015, 08:41 AM   #8
Flybob's Avatar
Couple cautions.
Running space heaters on a power bar may cause you an insurance problem if you ever have fire damage. Most every space heater has a warning not to run it on an extension/power strip. If investigator determines power bar caused fire, they could deny coverage.
Check with your park, just because there is a 30A and one or two 15A outlets in your pedestal does not mean that there is more than ( or much more than) 30A to that pedestal. Most RV parks/campgrounds will have a tree system of electrical service with other breakers upstream. For 30A pedestals usually they have 3 of them on a 100A breaker upstream. If each of the three sites uses 34 together at anytime, the 100A breaker will trip. This is significant as it usually means you need to find staff to unlock and reset breaker.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-26-2015, 10:34 AM   #9
Left Coast
Last week, I wired in an outlet inside for that very purpose...used gfi inside and a weather proof outside box........right underneath the 30 amp plug-in. WARM now!!
Old 12-26-2015, 11:06 AM   #10
DaveSchwartz's Avatar
I used to snake an extension cord through the slide gasket before I finished putting out the slide but after a few times I decided to I install this in the side of a slide closest to the 30A power inlet. Just had to cut a 2" hole with a hole saw (be careful to be a few inches up from the bottom to avoid the aluminum frame). Its very low profile on the outside (so it won't damage the gasket) and is on the interior when the slide is retracted. I use a 12 gauge single-receptacle extension cord (50', sometimes 2... thus the 12 guage and, yes, that's over 10 pounds of cable I carry). I've never been anywhere that didn't have a separately-breakered 15A receptable in addition to the 30A outlet on the post.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
