Old 12-01-2015, 08:26 PM   #1
How do I drain my fresh water tank?
So I've looked all over. I've been focusing under where you fill. I can't find a spigot, the owners manual is useless. I have a 2715 VS 2016 rockwood.
All I found was a red and blue pex coming from the under belly near the fill for the holding tank. I don't see anything at the low drain point label either.
Thanks, I feel so frustrated now.
episodic is offline   Reply With Quote
Old 12-01-2015, 08:42 PM   #2
Klbrown53's Avatar
My fresh water fill is on the entrance door side and my fresh water drain is on the opposite side just under the edge of the trailer. You pretty music have to get down on your knees to see mine.
Klbrown53 is offline   Reply With Quote
Old 12-04-2015, 11:52 PM   #3
You should see a drain valve on the tank itself usually within arms reach but laying on the ground is generally the only way to get to it.
Humteddy
2017 Surveyor 285 IKDS
2016 GMC Sierra Denali HD 2500 Duramax
Humteddy2 is offline   Reply With Quote
Old 12-05-2015, 04:18 PM   #4
gectisme's Avatar
On my WJ it is under the where the bedroom slide comes out, see the pic. With the slide in, it is easy to access.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper).
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 12-05-2015, 10:40 PM   #5
Once you find it, you may want to move it out to where you can get to it, like I did here on my Mini Lite:
Name:	Water tank drain painted.jpg
2011 Traverse LT, 3.6L, FWD
Old 12-05-2015, 11:04 PM   #6
Capt. Mike's Avatar
The red and blue lines ARE the low-point drains...red for the hot water lines, blue for the cold water lines that run through your trailer. If you wan to get the last little bit of water out of your water lines, take those caps off and it will drain there. Your fresh-water tank will have a small spigot on one end to drain it. On my Windjammer, it is on the opposite side of the trailer from the fresh water fill, and as others have said, you pretty much have to be down on the ground, under the trailer, to see and open it.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 12-06-2015, 02:15 PM   #7
He was looking for his TANK drain, Capt. Mike.
drain, fresh water, tank, water, water tank
