04-10-2015, 10:09 PM
How do I hook up TV outside?
Greetings! I have a 2502 TT and was wondering how I would hook my inside TV outside on a warm night to watch movies or to keep the kiddies outside!!!
Riders on the Storm
2014 Mini Lite 2502
2014 Ford F-250 Diesel
04-10-2015, 10:26 PM
Get a long coax, a union and connect the coax up, drag the TV outside and plug it in
04-10-2015, 10:34 PM
Riders on the Storm
2014 Mini Lite 2502
Ever try watching a campfire? No wires nothing to hookup!
04-11-2015, 11:14 AM
Great point! Thanks.
Riders on the Storm
2014 Mini Lite 2502
04-11-2015, 12:58 PM
Riders on the Storm
2014 Mini Lite 2502
Put Pink Floyd on outside speakers to drown out the neighbors, a steak on the barbie and a beer to time it by - it doesn't get much better than that!
04-11-2015, 01:35 PM
Do what donn said. I leave the mount on the bottom just in case i take it outside.
04-11-2015, 01:37 PM
We keep it co-ax'd to the inside, power on the outside. Set the tv on the outside shelf, or picnic table. Have played movies, or watched the Tigers in the post season last year. Sit by the fire, watching Detroit Tigers baseball... heaven.
Joe & Sue - Camp Mutt Duke
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
04-11-2015, 01:46 PM
hotzfamily. You meant the Dodgers right.;o)
04-11-2015, 02:33 PM
how is the tv disconnected from the swing arm.....the 4 screws on the holding plate ???.......24" furrion on a 2015 rockwood mininlite 2109.
04-11-2015, 03:02 PM
dee. There are different types. Post a pic and we will tell you how.
04-11-2015, 03:04 PM
Usually you just lift up on the TV. There should be a matching bracket outside to slip it down on.
Outside there should be a coax connector. Run that to your TV antenna input. It will let you get the antenna signal and if you have park cable that will come in to the TV if you push the little button on the wall plate inside. It will not get the DVD player unless you run additional cables. (your results may vary)
04-11-2015, 03:11 PM
Some swing arms have two thumb screws that have to be removed before you can remove the TV.
04-11-2015, 03:58 PM
Dam farm liked it all except the pink Floyd part. How bout some reggae or blues?
FOREST RIVER FW 8524RLWS
2010 FORD F 150 5.4
#1-18' Nomad #2- 20' Mallard #3- 27' Sunline #4- Four Winds C #5- Innsbruck 40' PARK # 6- 28' Amerilite #7- Forest River 26.5 FW ( 1st FW)
04-11-2015, 04:02 PM
Sounds good to us!
04-11-2015, 04:25 PM
Jazz is also good listening at times.
04-11-2015, 05:19 PM
Rock on music loving campers.
2010 FORD F 150 5.4
04-11-2015, 07:45 PM
If you have cable/satellite hookups you can run your output to the cable connection inside and run a coax cable to your TV outside. It will work as an output as well as an input. I do it all the time with my satellite.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
04-11-2015, 08:25 PM
Nobody has mentioned a splitter.......Put a splitter on the main feed to TT......1 output to main IP on trailer and second feed to outside TV.......Two TV's????? can now work
04-11-2015, 09:05 PM
There should be a coax jack on the side of the trailer below the mount for the TV. That coax already has a splitter off of the feed for the TV. No additional splitting needed. Hopefully your trailer has that coax jack.
04-11-2015, 09:35 PM
I didn't bother with pulling the tv out we bought a cheap projector and call this our drive in movie. We have a small dvd player with us that is hooked up normally to bedroom tv and hook it up to our projector. We can have up to a 6' screen and we have had several of the neighbors kids come over and join our grand kids to watch. We usually get a little nostalgic and start with a cartoon before the movie just as they did when we were kids and our parents took us to the drive - in. I think I got it for under $100 several years ago.
Think about things before you do them make life easier not harder.
