Old 06-23-2018, 11:27 AM   #1
How do I remove pex fittings
Hopefully my picture will show up. Removed the water filter. Now need to connect with a shark bite fitting but will need to remove the white connectors first. How do I do this?
2018 Flagstaff Micro Lite 23LB
Equalizer 4 PT. WDH 1k/10k
2012 Jeep Grand Cherokee V8 4x4
jk70 is offline   Reply With Quote
Old 06-23-2018, 11:31 AM   #2
if you have a few extra inches of pipe to spare just cut it.
Kimber45 is offline   Reply With Quote
Old 06-23-2018, 11:35 AM   #3
NMWildcat's Avatar
For myself, the easiest thing to do is just cut the tubing below the nipple of the fitting (the part inside the tubing) to get to the part of the tubing that hasn't been deformed by crimping. Then just add in the necessary length of additional tubing to replace where the filter was.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-23-2018, 11:35 AM   #4
I think i should have some room to spare. I assume I need to grab a pex pipe cutting tool?
Old 06-23-2018, 11:36 AM   #5
any heavy duty tubing cutter will cut the 1/2 inch stuff.
Old 06-23-2018, 11:38 AM   #6
NMWildcat's Avatar
I just used a box cutter on mine, but a tubing cutter would leave a nicer edge.
Old 06-23-2018, 12:35 PM   #7
Thanks everyone. I cut the pex pipes and attached with a shark bite. Real test is when I turn on the water
Old 06-23-2018, 12:54 PM   #8
NMWildcat's Avatar
Good luck!!!
Old 06-23-2018, 01:12 PM   #9
sharkbites are the cats meow!!!
Firedude26 is offline   Reply With Quote
Old 06-23-2018, 01:38 PM   #10
I agree. Almost felt like something was wrong how easy it was to put together. Ran water through the system and so far so good. Finally, got that water filter removed. On my mind the past few months.
Just sanitized the fresh water tank so that's done (don't usually use it). nice to have a free day to get things done
